slow rim leak on WD |
Dennis IL
Joined: 23 Sep 2009 Location: Illinois Points: 7840 |
Topic: slow rim leak on WDPosted: 12 Jun 2010 at 9:48pm |
I have a very slow rim leak on the Wd right around the valve stem (there was cc in there but I drained it out because that's what was rusting it out) the rest of the rim is excellent. What I'm wondering is if you guys think a little JB weld might do the trick? Dennis.
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7639 |
Posted: 13 Jun 2010 at 8:53am |
It's your tube that is leaking - not the rim. However, a rough patch inside the rim could be causing the tube to leak.
BennyLumpkin
Joined: 22 Mar 2010 Location: Centre Hall, PA Points: 2657 |
Posted: 13 Jun 2010 at 8:55am |
exactly...if you dont mind the look of the rust outside...pop the tire off and clean the rough area inside, and re-tube it....its the only real fix.
