Slipping steering clutches
rhead1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rhead1 Quote  Post ReplyReply Direct Link To This Post Topic: Slipping steering clutches
    Posted: 29 May 2019 at 6:01am
I have my HD6B up and running pushing a lot of dirt but I think I have a slipping clutch problem. When I put the clutches together...using all exiting bi metal plates.... I had to add steel plates two per side to get the proper stack height. I put them together the first time just like the manual states which is the friction plate against the pressure plate. In doing this, the first friction plate( once installed in to the flanges) was just on the edge of the drum and came misaligned with the stack. This caused a very hard removal of the steering clutch. I removed both clutches and rebuilt them with the steel disc up against the pressure plate which put the friction discs teeth further in the drum. Is this causing the slipping problem or are my discs worn out. They spec’ed out at around .148 thick. The book said they were good till .125. Another indication of the slipping is when put into gear (2nd forward and reverse) it has a bit of a run up to speed and if I am going up a incline it’s a bit of a struggle to get full speed. Sorry for the long description
Ages Cat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2019 at 7:48pm
I have had the main clutch slip on several tractors. It sounds like your main clutch is slipping.
Curt Anderson
HD3, HD5B, HD6AG,HD6B dozer, I-400,615, 616,620,720,ACP25 lift truck, 1956 D Grader, AC 540 loader, AC #84 plow, Simplicity tractors, Agco MT225, Agco 2025,
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2019 at 12:13pm
Seems steering clutch slip - unless they are oil soaked composition is a rare thing - now have heard splines hanging up on bi-metal but unusual .
 Might pay to check master clutch further as suggested above
Post Options Post Options   Thanks (0) Thanks(0)   Quote rhead1 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2019 at 7:59am
Would the test be to just tighten the clutch one notch and rerun the machine to see if there is a difference?
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2019 at 8:18am
Unusual that both steering clutches would slip the same. Master clutch is the common point if the drive is equally weak side to side. Check the master clutch as others posted.
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2019 at 9:59am
You should have more than 2  11/16 inchs and make sure the pressure plate is't ben by inside and could missing pression on discs
Post Options Post Options   Thanks (0) Thanks(0)   Quote rhead1 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2019 at 6:50am
I don't understand the dimension listed.  Is it the dimension setting the clutch lever?
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2019 at 7:41am
  yes i believe that is the steering clutch free play lever dimension.  measured at the tip of the lever.  any shorter than that the yoke could be staying in contact and not releasing fully especially after use when the clutch gets warm.  can cause slipping and premature release bearing failure
Edited by CAL(KS) - 04 Jun 2019 at 7:43am
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2019 at 12:27pm
The new stering cluch is 2 7/8 inchs but can be use until 2 11/16 inchs and you should have 3 inchs free travel when measured at the top of the lever and you should have 1 3/4  inchs to 2 inchs free travel on brake pedal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rhead1 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2019 at 4:58am
Thank You all for your help.  It was the Master clutch slipping.  I adjusted it tighter one notch and works great.  I will double check the steering clutch free travel.
