Slightly OT: CAT70 scraper
Andrew_D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrew_D Quote  Post ReplyReply Direct Link To This Post Topic: Slightly OT: CAT70 scraper
    Posted: 27 Aug 2014 at 8:33pm
Posted this on HeavyEquipmentForum and ACMOC. Any suggestions from here?
Found a loose bearing on the front axle of our CAT70. Went to tighten the nut and found that someone has been into this before. The nut is very loose on the shaft threads. Decided to pull the stub and see what we can do...
Removed the 1" bolt and 5/8" bolt from the axle tube. Cleaned up all the grime from around the stub shaft and from the slit in the bottom of the axle tube. Knocked a couple of punches into the slit at the bottom of the tube to try to spread it open a bit. Put a couple more chisels between the axle stub shoulder and the axle tube.
Have been tapping on the axle tube and going at the axle stub shoulder with the air hammer to no avail.
Then cut a piece of tube to fit over the axle stub, a bit bigger than the shoulder, to bear against the end of the axle tube. Made a plate for the end and carefully threaded the axle nut back on. We have the nut fairly snug but don't want to over do it because the threads aren't the greatest (the whole reason for this operation!)
Any other ideas?
Andrew
HD11B (S/N: 3880) ~1957
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2014 at 8:39pm
Grind the threads off, and re-thread next size smaller?
chumduffy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chumduffy Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2014 at 4:07am
Andrew,
        Hello. Not sure what to tell you, We have had a Cat 435 F sense 1973 however I have never had the need to take a front wheel apart yet!! It has spent most of it's time hooked to a Cat, D8-2U. Lately it has been only used at antique tractor shows. I hope you have as good of luck with your Cat 70 as we have with our 435-F! It has been a excellent piece of equipment! What will you pull your scraper with?, Do you have much work for it? Is your scraper still set up as a cable machine? Operating tractor scrapers was always one of my favorite things to do!! Look forward to your reply. Thanks,Chum....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrew_D Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2014 at 6:42am
Chum:
Ours has been converted to hydraulic. As with most scrapers around here, it is pulled with an ag tractor.
Dave:
I was hoping to pull the stub shaft and throw it in the lathe to turn the section down and re-thread. Hadn't thought about trying to grind it while mounted....
Andrew
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2014 at 6:04pm
Andrew, if you can do it, and if the axle stub has a center hole, and you can find the right sized hole saw, you can do it that way.  The trick is in getting the die started straight, so the nut goes on exactly straight. Some times you just don't have the room...
This page was generated in 0.234 seconds.
