sleeve to replace hand clutch assy.
autobody View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote autobody Quote  Post ReplyReply Direct Link To This Post Topic: sleeve to replace hand clutch assy.
    Posted: 20 Apr 2016 at 2:52pm
Does someone sell a sleeve to replace the hand clutch assy. On a wd
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2016 at 3:05pm
there are some people that make them.  i believe its the same splined sleeve that couples WC trans to pinion shaft.
48ACWD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 48ACWD Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2016 at 6:25pm
I'm looking to replace mine with a coupler as well to help loose some weight. Any idea who to contact for one. Thanks
Larry(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2016 at 5:25am
Ken(MI)
'40 WC puller, '65 770 Ollie
*ALLIS EXPRESS contact*
I can explain it to you, BUT I cannot understand it for you!!
Ken(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2016 at 4:49pm
 We have them on the shelf, $60.00, including shipping. My cell is 517 712-1896, anytime between 7:00am and 7:00pm eastern time.
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2016 at 5:50am
How do you seal the transmission up?
Or if someone has a photo would help me understand
Thanks
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2016 at 10:40am
This is a 10-spline X 1.375" coupler to eliminate the hand clutch assembly. Still uses the existing torque housing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2016 at 11:15am
Ah, OK.
I was thing you were dropping the whole housing
Charlie
This page was generated in 0.088 seconds.
