Sleeve kits
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Topic: Sleeve kits
    Posted: 30 Oct 2010 at 2:25pm
I was talking to a guy today that stopped me as I was out and about on my B and he was telling me that Sleeve kits from 138, 149 and 160 engines would fit my 125 engine. I didn't think they would as I told him that the D10/12/14/15 used the same basic engine and that they probably would have been interchangeable but the 125 was a different design.
So what says the forum?
Charlie
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2010 at 2:58pm
The sleeves for the D 10 thru D 15 are not only larger around than what you have in your B, the O rings for them mount in grooves in the block rather than around the sleeve as with your B.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2010 at 4:52pm
Dick, didn't you manage to stick D15 internals in a 125 block?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2010 at 7:19pm
Yes but I had to bore the block and then put 1/2" of expandable cement in the bottom of the block to seal sleeves.  Not something that you buy and slip in.
