Skid Steer Quick attach implements?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: Skid Steer Quick attach implements?
    Posted: 24 Feb 2026 at 9:15am
Are all skid steer quick attach plates the same? I want to build a conversion for my Oliver 1610 to skid steer quick attach. Is the same size plate welded to the bucket, grapple or what ever implement? Any help appreciated. Thanks, Tracy.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2026 at 9:44am
Pretty much... The plates vary by 1/2" in width, depending on who makes it.... Basically the "PLATE" on the implement is 45 inches wide and and has a 45 degree back angle at the top.... the part you weld to the tractor / 3 point / loader arms is about 44 inches wide and has a 45 POINT at the top of the plate.. The tractor end can be two parts or one big part.. I just did this on an old GEHL... Cut the back face of the bucket off and welded on the 45 inch wide PLATE... then cut the old GEHL quick hitch HOOKS off and adapted the UNIVERSAL QUICK HITCH to each boom arm... I used two different parts for the tractor.. one for each boom arm... you can buy ONE complete mount..
GOOGLE-----------
Universal skid steer attachments follow the SAE J2513 standard, featuring a ~45-inch wide, 18.5-inch tall mounting plate with 1.25-inch tapered locking pins spaced ~31.6 inches apart. The top angle is 45°, while the bottom angle is 120°, designed to fit most modern loaders. Key specifications include a top hook-over, bottom pin-locking system, often with 5/16" or 1/2" steel.
Edited by steve(ill) - 24 Feb 2026 at 3:53pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2026 at 9:49am
this is the PLATE that welds to the bucket or forks..... there are normally  4 LOCK holes at the bottom.. the OUTER TWO will be used by most tractors and skid steers... the INNER two lock holes are if you put on a MINI SKID and the boom is only 24- 30 inches wide, you can still mount the BIG forks or BIG bucket.
You dont need 1/2 inch thick plate... Im just showing this picture because it gave dimensions of the plate width / height / lock kholes.
Edited by steve(ill) - 24 Feb 2026 at 3:54pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2026 at 9:51am
what i found out is the PLATE that welds to the BUCKET should tilt forward and not be VERTICAL.. I forget right now, but something like 20 degrees ??? That gives you room to curl the bucket BACK when loaded.... not a big deal on the FORKS as they normally run LEVEL and not a lot of tilt back needed.
GOOGLE---
The standard mounting angle for a skid steer quick hitch (SSQA) is typically 20 to 25 degrees off vertical (or roughly 65-70 degrees from horizontal). This forward-tilted angle ensures that attachments properly seat, lock securely, and allow for optimal bucket dumping or proper positioning of pallet forks
Edited by steve(ill) - 24 Feb 2026 at 9:53am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2026 at 11:27am
Steve, you are a wealth of info. This is what I needed to know. What is average thickness of weld on plate? I have not seen one a half inch thick on anything around here. Thanks, Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2026 at 11:50am
There is a place about 2 hrs from here that make adapters. Bell Precision tool in Shelbyville. They look pretty good. Thanks, Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2026 at 12:17pm
5/16 inch thick is probably the standard if you got a small skid steer or tractor like 30 HP... If you got 40- 60 HP you go to the 3/8 inch think.... The 1/2 inch would be for a BIG tractor that your loading a couple tons ( 4000 #) in the bucket..
Edited by steve(ill) - 24 Feb 2026 at 12:18pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2026 at 3:37pm
Actually there are 4 sizes that I know of.  Smallest is the one that fits the 15 HP toro dingo, then there is the 30 HP ASV rc-30, then the weird bobcat proprietary one, then the full size one on bigger machines(above mentioned).  I would go full size on anything tractor mounted. Check out Auctionzip.com, there are numerous auctions that sell the full size attachment plates, likely one close to you.  For My ASV, I made a wooden template to mock up the male end, and used it to move the lower ears up, and weld them in a new spot, easy-peasy...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2026 at 6:14pm
The biggest challenge is mounting the LIFT BARS onto your tractor.. Each tractor has a different size boom and pin spacing.. You can buy universal lift bars for  $100- 150. and then MAKE plates and weld to the bars to mount to your boom PINS.... Or if you dont want the challenge, there are companies that make SPECIFIC MOUNTS to fit SPECIFIC tractors.. You can Google "skid steer hitch to adapt to Oliver 1610" if your interested.. They are NOT cheap, but easy compared to design and build your own..
Dirt Farmer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dirt Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2026 at 3:12am
Worksaver in Litchfield Illinois makes replacement brackets for several tractor brands as well as many attachments for loader tractors and skid steers. They are a worldwide company and manufacture all of their products in house. Very helpful and friendly folks. They have a website if you google worksaver.
