Skid Steer Brush Cutter Info
Jack(Ky) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack(Ky) Quote  Post ReplyReply Direct Link To This Post Topic: Skid Steer Brush Cutter Info
    Posted: 20 Aug 2010 at 5:29am
Have customer that wants me to get him a hyd motor to put on a 5ft bushhog so he can mount it on his skid steer. I thought someone might have one and could give me the numbers on the motor. Thanks, Jack P.
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2010 at 7:45am
I cant help you with the exact part number but there are two standard skidsteer hydraulic systems. High flow and regular, I think the hi flow is 17GPM, cant remember the other. You need to know which he has before you do much searching and make sure whoever gives you a reccomendation knows what the are talking about. Our local tool rental place has brush cutters for both types so I know they are available, you dont mix them.
Sam T-Ga View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sam T-Ga Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2010 at 9:58am
Most reg flow skidsteers are in the 15-18 gpm. High flows are 40 gpms. Make sure he has a front door made from 5/8 lexan. It will throw sticks and ROCKS in the cab without it.  Sam T-GA.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2010 at 10:11am
Ooops, happens when I go from (feeble) memory.
R Aiken View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R Aiken Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2010 at 10:20am
I have some hydrolic motors that might work for what you want to do. They are off a haybine, baler and some smaller ones.
Richard
This page was generated in 0.046 seconds.
