Sinopec oil 15w40 HD Diesel oil |
| Author | ||||||||||||
captaindana
Joined: 14 Sep 2009 Location: Fort Plain, NY Points: 2579 |
Topic: Sinopec oil 15w40 HD Diesel oilPosted: 09 Aug 2024 at 6:59am |
Thoughts? When I read specs Im like a dog watchin’ tv.
Blue Skies and Tail Winds
Dana |
| Sponsored Links | ||||||||||||
Codger
Posted: 09 Aug 2024 at 7:23am |
I have a barrel of 15W-40, but have not ran a full oil change interval on it as of yet. Nothing unexpected has happened and it's just another engine oil IMO. The specs met what was needed for my Allis 11-B dozer, so evaluating it there.
That's All Folks!
Joined: 11 Sep 2009 Location: illinois Points: 88642 |
Posted: 09 Aug 2024 at 7:29am |
ALl oils have an SAE spec.. Autos are Sx and diesels are Cx... where the "X" changes over the years with oil refinements... Allis is old enough that just about ANY Cx oil is acceptable..
Diesel Engines(Follow your vehicle manufacturer’s recommendations on oil performance levels)
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5164 |
Posted: 09 Aug 2024 at 1:49pm |
My concern would be the Zinc content needed for the old flat tappet camshaft. I was just into an engine ruined by the owner using the latest/greatest flavor of the month oil where the lobes were wiped off and the tappets where all but wore off as well.
NEVER green
Posted: 10 Aug 2024 at 10:11am |
Many a classic car owner has had this problem, they will claim the modern oil additives are better then zinc but I call BS. ALL break in oils are high in zinc for a reason.
1963D17
Joined: 05 Jun 2021 Location: Alvord, Iowa Points: 90 |
Posted: 10 Aug 2024 at 1:45pm |
I've always used zinc additive in my older cars. Now use Valvoline VR racing oil which has zinc. Bought an older pre-roller cam Pontiac Sunbird this spring. Cam and lifers were worn bad from no zinc.
