Single Bottom Plow
PBSoMd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PBSoMd Quote  Post ReplyReply Direct Link To This Post Topic: Single Bottom Plow
    Posted: 20 Feb 2011 at 9:28am
What's this plow worth? It come with a C that I picked up couple of years ago, not sure if it fits a C  or a B or both?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2011 at 9:45am
Nice looking plow. It should work on either a B or a C. The drawbar it attaches to is different between the 2 tractors. Wish I had it for my B but I already have 3 different plows and only have ever used 2 of them.
Darrell, Jr. (MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darrell, Jr. (MN) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2011 at 11:01am
the Value of that plow depends on where you are at in the country.  In your area it's not worth what it is to the west of you.  That plow has the chilled (cast iron) moldboard as was only made out East.  It's pretty rusty, but it looks like it is not all bent up.  Like Charlie said you need all the mounting hardware to mount it to either a B or C and without that it cuts the value down.  If I had to put a number on it I would say a fair price would be in $100-$150 range, give or take $50, just the way it sits
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2011 at 11:02am
Fits both.
If the moldboard is not cracked, it is the most valuable part of that plow.
Typical prices for that piece would be anywhere from $60 -$120, depending on the buyer and how much money was burning in their pocket.
Jacob (WI,ND) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jacob (WI,ND) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2011 at 2:33pm
I agree with the others.  I'd say no more than $100 unless you have all the mounting brackets and hardware, which seem to be the harder parts to find.
Jacob Swanson
1920 6-12; 1925,1926 20-35 longfenders; 1925,1926 15-25's; 1927,1929 20-35 shortfenders; C; B's; IB; WC's; WD; WD45
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2011 at 9:21pm
I didn't lok where California MD is located, but I might be interested in your plow.
Bob
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 10:02am
Just curious;  would the matching LH plow (with the Allis-Chalmers cast in) be worth more than the RH plow? That's assuming they made a LH in that style.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 10:16am
Brian G. NY - no, typically not.
They did make the LH in that style, but my experience is that they might actually be worth less, as the righthand setup is what the drawbar and rockshaft is set up for.
You need to have all the RH parts, in order to use the LH setup. If you have a full set (RH/LH) then the combination is probably worth more than the sum of the parts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PBSoMd Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2011 at 8:04pm
Bob
I will probably keep it and paint it up for decoration
Thanks for the info
This page was generated in 0.217 seconds.
