Since I have been "Head Cook" ,,,, |
desertjoe
Joined: 23 Sep 2013 Location: New mexico Points: 13769 |
Topic: Since I have been "Head Cook" ,,,,Posted: 23 Sep 2018 at 11:41pm |
As a lot of youse Guys know,,,that due to my wife's unfortunate surgery,,,I have been promoted to "Head Cook" and #1 dishwasher as well,,,,,,, ![]() A couple of Christmas ago, one of the boys gave us a set of real nice stainless pots and pans,,Calphalon brand. The 4 pans are bout 1/4" stainless and the 4 pots as well. In the last 6-8 months,,I have noticed they are startin to get a kinda brown stain on the underside and very hard to get off and gettin worse as time goes. I even tried some of those scrubs with ajax soap in em but still cannot get all the stain off. Anybody havin that issue with theirs, and what do you or your wife uses,,??? We are on propane but the other set we had,,Paula Dean did not do this,,????
shameless dude
Posted: 24 Sep 2018 at 12:23am |
Joe...puts one of them metal cleaning discs in your electric drill. that's how I clean mine. one night I burnt sum food in one of our pans, scraped as much out as I could, then took that disc and drill to it...came out nice and shiney! it's one of them discs that look like a bunch of spider webs all welded together...dunno what they are called
CaseyCreek
Posted: 24 Sep 2018 at 10:00am |
I usually see a burnt/browned bottom of a skillet as a character mark. However, if you want to take the burner marks off, you can try oven cleaner. DO NOT use the yellow Easy Off. It says it is safe for stainless and it would probably work fine, but I have seen where people put it on stuff that they THOUGHT was stainless and it wasn't. Usually refrigerators. Whew! The blue Easy Off or the cheap stuff in the dollar store should do the trick. I would start with a test on your least valuable skillet first.
D17 Series III,D17 Series IV, 185
john(MI)
Posted: 24 Sep 2018 at 10:31am |
That's what we call "seasoned"? If they have the non stick inside, we wash those with a drop of dawn and hot water. Use a plastic brush a little as possible, rinse then dry with a paper towel. The wife has cut that real thin sheet styrafoam into squares and it is put between the pans.
Ted J
Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18967 |
Posted: 24 Sep 2018 at 11:39am |
I don't bother with cleaning the bottoms,,,,,,,,,,,,it'd be a days work all too often. Gives em character. I use cheap paper plates between them when storing.
Hubert (Ga)engine7
Joined: 12 Sep 2009 Location: Jackson Cnty,GA Points: 6610 |
Posted: 24 Sep 2018 at 12:33pm |
Fiber disc in a drill and then some buffing compound and a small buffing pad. Or just put them away and get you some good cast iron.
chaskaduo
Joined: 26 Nov 2016 Location: Twin Cities Points: 5200 |
Posted: 24 Sep 2018 at 1:04pm |
Joe are you trying to impress the visiting nurse?
