Simplicity numbers of Deutz Allis 1920
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Topic: Simplicity numbers of Deutz Allis 1920
    Posted: 04 Apr 2017 at 4:51am
Would anyone know the Simplicity model numbers that's the same as a Deutz Allis 1920? Told them I had a DA 1920 got the ole blank stare, needing the bushings that center the blade on the arbor shaft , would think they are common on alot of Simplicity models
Edited by DougG - 04 Apr 2017 at 6:08am
tractorman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorman Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2017 at 8:46am
try  for  the  decks  on  the Sunstar  that  is the  Simp  equvalent ,  chances are the bearings  themselves have numbers on them if not  too far gone to show.  or  a good  bearing  shop  can measur and match the size  , just  my  3 cents worth .
Play on 38 B 49 WF , working on D14, D15 B10, Bee 12 B110. use 185 and 190
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2017 at 9:14am
Thanks,, I just need the bushings that center the blade , thanks again
Edited by DougG - 04 Apr 2017 at 6:01pm
DSpears N IL View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSpears N IL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2017 at 8:28pm
Doug, I have a Agco-Allis 1920 lawn tractor and the manuals.
I have taken 2 photos of the deck parts and part numbers for you.
I hope that this is the information that you are asking for!
DeWayne
LaJaMe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LaJaMe Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2017 at 12:19am
I have a Deutz 1920 and a Simplicity GTH 20hp model # 1691926  All attachments are inter changeable between these  two models.  Wait till you get the stare when you say GTH 20.  Have model # handy.  Just purchased 2 for my 48" deck the other day.  Local Simplicity dealer said they had a lot in stock.  I have also had good results with partstree.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LaJaMe Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2017 at 8:08am
Sorry DougG didn't read your comments correctly.  I would try Partstree as I said before.  I've had great luck with them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorman Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2017 at 9:14am
the simplicity 1920  is   the   Sunstar
This page was generated in 0.445 seconds.
