Simpicity Regent Stuck in Reverse |
AJ
Topic: Simpicity Regent Stuck in ReversePosted: 07 May 2014 at 6:25pm |
Anyone have an idea of why my mower suddenly got stuck in reverse? The shifter don't seem like it is catching on anything like it did before. It's a 5-speed.
Can't fix stupid
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4070 |
Posted: 07 May 2014 at 7:15pm |
does it have a peerless700 it may have a broken shifterkey in side the trans very easy to work if there are mower racers around you they all have parts thats the trans they use most of those guys take the reverse gears out of the trans to lower the rotating mass and less to blow up at 40 mph
HudCo
Posted: 07 May 2014 at 7:19pm |
if it is apeerless transaxle it is about the same inside the grease is messy
AJ
Posted: 07 May 2014 at 9:20pm |
Well I figured out that the lower casing is broken and has lots of moisture and corrosion inside the transaxle. So looks like I need a new transaxle. It is a peerless. What other mower were these used in? It's a 5-speed
Can't fix stupid
AJ
Posted: 07 May 2014 at 10:04pm |
Anyone have an axle?
Can't fix stupid
HudCo
Posted: 08 May 2014 at 10:34am |
later 76 78 ish johndeere108 i believe its 900- go to your local mower shop that does tecumseh and they can order you all the parts books
AJ
Posted: 08 May 2014 at 1:13pm |
This mower is from the prolly the 90s
Can't fix stupid
