Silent 620
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Topic: Silent 620
    Posted: 26 Jun 2010 at 11:01pm
Question for the 620/720 experts here.  I've had it apart for the last few weeks getting the gas tank cleaned, new fuel filter, and cleaned and adjusted the carb.  I put everything back together, now I can't get a sound from the starter.  All lights work, and the battery has plenty of juice.  Is there a blown fuse somewhere?  Will the engine have to come out to access the starter (God, I hope not!).  It started great before I took the fuel system apart.
I would appreciate any help!  Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2010 at 11:38pm
Have you checked the safety switches? HTH Tracy Martin
Larry Miller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry Miller Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2010 at 11:54pm
I know you have to pull the engine to get to the starter, and then it is behind the cowling. I had mine out three or four times before I found the bad winding in the starter. It ran on the bench but not under any load.
Check the ground connections first.
I used to be young and stupid, now I am not young anymore.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2010 at 12:20am
Tracy, Where are the safety switches on it?  I am not that familiar with it yet...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2010 at 8:56am
I think one on clutch pedal, or actuated by pedal, could be at tranny. I know there is one on hydro levers, must be in neutral to start.Pretty sure all pto clutches must be off also.HTH Tracy Martin
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2010 at 9:09am
  by pass all switches go directly to staRTer with a jumper  if starter workks problem then is safety switches will help solve your problems and elimate a lot of work  ten look for problem  40+ yrs. under my belt
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2010 at 9:10am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2010 at 7:16pm
Problem solved - clean the connections on the ignition switch!
DREAM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2010 at 9:39pm
Glad you got that D series. I was gonna join in. Have worked on a few of the Simplicity models of those. Glad you didn't have to get the starter off. Engine does have to come out. I would recommend replacing/rebuilding anything else you thought might EVER wear out in that area while you had it out.LOL! It's not as bad as working on some Toros, but it still sucks!
This page was generated in 1.650 seconds.
