Sidedress fertilizer questions? |
   Eric[IL]
   Joined: 14 Sep 2009 Location: Illinois Points: 485  |
      Quote   Reply
     Topic: Sidedress fertilizer questions?Posted: 02 Feb 2010 at 8:12am  |
    I have an old cultivator toolbar that I am going to convert over to a liquid fertilizer sidedress toolbar applicator.   |
   Gerald J.
   Joined: 12 Sep 2009 Location: Hamilton Co, IA Points: 5636  |
      Quote   Reply
     Posted: 02 Feb 2010 at 9:25am |
   I used an AC plow coulter with the thin knife behind it. Worked fine with 32%. I mounted it on front of the planter first to put down 32% off a couple inches from the row which also cut the residue so the trash wheels could part it and not leave it for the planter opener disks to hairpin stems.
  I have also used a vintage planter as the side dresser, at 60 inch spacings. And my best corn year, I used flexible drops after my coulter assembly broke the first pass across the field. Got 173.2 bushel corn after poor beans from 111 pounds of N per acre. I believe variety selection was important there too. Over on New AG Talk crops forum side dressing is discussed a great deal. I did not use a rippled coulter, I did not want the dirt packing in wet spots. Gerald J.  |
   Mike NEIN
   Joined: 15 Jan 2010 Location: Rome City, IN Points: 405  |
      Quote   Reply
     Posted: 02 Feb 2010 at 10:48am |
   These work great as long as you don't have any corn stalks to go through.My biggest complaint is getting cobs between the colter and the knife, then it starts dragging. Hope this helps.
| Forum Jump | Forum Permissions  ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum  |
