side shields
allispuller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allispuller Quote  Post ReplyReply Direct Link To This Post Topic: side shields
    Posted: 02 Mar 2015 at 3:16pm
Was wanting to put side shields on my wd45 and was wonder what others were using and how you had them mounted
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2015 at 11:16am
The easiest thing is find a set of cornpicker shields. I've know some place the on stock classes would only allow OEM side shields. Most likely a rule started by the other green tractors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allispuller Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2015 at 12:28pm
I thought about the picler shields buy where i pull there isnt that rule so im thinkin about makin my own just gettin ideas
nborga87 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nborga87 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2015 at 3:26am
just make them out of sheet metal with some quarter turn fasteners to hold them on. i like the way those cornpicker side sheilds look but the ones ive found they want a lot of money for them
Post Options Post Options   Thanks (0) Thanks(0)   Quote allispuller Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2015 at 7:56am
Thats the thing ive ran into is that everyone wants alot for them. Did you go through the stock tin or did you make a brackey for your fasteners to go into
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2015 at 11:01am
I've just cut a piece of aluminum that fits then put longer bolts to hold the hood on with the nuts outward. Then use wing nuts for the shield. A rubber strap at the rear under the gas tank work fine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allispuller Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2015 at 12:08pm
Thanks guys if anyone has pictures i wouldnt mind seeing them
Post Options Post Options   Thanks (0) Thanks(0)   Quote nborga87 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2015 at 5:30pm
i went into the hood and grill. two fasteners in the hood and one on the side of the grill
