sickle sections/ bolts or rivets?? |
Post Reply |
SHAMELESS
Orange Level Joined: 13 Sep 2009 Location: EAST NE Points: 29486 |
Posted: 09 Mar 2016 at 8:16pm |
yep, i'll never go back to rivits either!
SteveM C/IL
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8036 |
No experience with sickle mowers but would never go back to rivets on the combine sickle.Can change sections on the combine without removeing anything other than bolts.It's quicker too.
Macon Rounds
Orange Level Joined: 18 Feb 2010 Location: Pittsburgh Pa Points: 2071 |
word of caution. The bolts are pleanty strong for shear load as they experiance from typical cutting action, however they are easily broken if tigened agressively at installation.
tadams(OH)
Orange Level Access Joined: 17 Sep 2009 Location: Jeromesville, O Points: 9709 |
The section don't set higher. You have to run higher hold downs for the nut & end of bolt to clear.
Tom
HD6GTOM
Orange Level Joined: 30 Nov 2009 Location: MADISON CO IA Points: 6627 |
I will only run bolted sections, just too much trouble to rivet them on even with the sickle repair tool.
DonDittmar
Orange Level Joined: 15 Sep 2009 Location: MIllersburg, MI Points: 2476 |
It does. You need the hi rise clips to clear. Ran into this on a JD #5 mower when we switched to bolted sections
Edited by DonDittmar - 09 Mar 2016 at 12:30pm |
1968 D15D,1962 D19D Also 1965 Cub Loboy and 1958 JD 720 Diesel Pony Start |
tractorboy
Silver Level Joined: 03 Oct 2009 Location: southern Va Points: 448 |
Gonna order new sections from sickle sevice, I see they come with the bolts. My question is does the bolt head make the section set too high?? I know too much clearence adds to clogging. I want to put it back together without making a lot of adjustments! thanks keith
Post Reply | |
