sickle mower
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Topic: sickle mower
    Posted: 27 Feb 2023 at 11:05am
is this s'posed to mount on a wd or 45? I have no use for it but never saw one like this before.
Edited by ac fleet - 27 Feb 2023 at 11:10am
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2023 at 8:36pm
WD and 45 would be same mount. Never saw one like it.                    MACK
200Tom1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200Tom1 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2023 at 9:07pm
Its been 55 years since I seen it, but it sorta looks like the belly mower grandpa had on his C.
Travis2766 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis2766 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2023 at 9:51pm
I’m thinking for a B or C.
190XT Series III, D17 Series IV, D15 Series II, All Crop 66, Rotobaler.
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2023 at 7:26am
It doesn't look like the mowers (three of them) I have for my Model C, but I am far from expert. Confused
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2023 at 1:30pm
I have one on a C and its WAY different  so not for c! Looks to mount to rear of wd/45 drawbar along the side of the housing. Total mount with no tailwheel on whatever model it is,---other than allis!
jvin248 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jvin248 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2023 at 3:31pm
Could be a Case model. That's a super long wood connector bar to move the blade. My father's WD full rear mounted mower had one only 18-24in from memory, it broke once and he made a replacement. I used to sharpen the teeth on that mower.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2023 at 9:33am
I have pictures of quite a few A-C mowers including #3, #5, B/C  and WC and I can't see anything on your mower that looks  like those. The hinge on the inner shoe is totally different for one thing. This may be a rear mount mower as it appears to have a drawbar attached to it. I remember a neighbor farmer who had a Ford rear mount mower with a drawbar but not like yours. I'm guessing your mower may be made by someone other than A-C and was simply painted to match an A-C tractor it may have been mounted on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2023 at 9:45am
The guy I got it from said his dad had an allis tractor but he dont remember what model but thought wd sounded right.
It has a solid pto extension about 3 feet long with sleeve on 1 end and 6 splines on the other end for the vee pulley to go on.
Looks allis made cause of how complicated its made which is the trademark of allis equipment! lol! They go around the block just to cross the street in their designs!
