Sickle mower - WD
1953ACWD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1953ACWD Quote  Post ReplyReply Direct Link To This Post Topic: Sickle mower - WD
    Posted: 19 Oct 2021 at 8:01pm
Which sickle bar mower best matches up with a 1953 WD?  Thank you in advance.
1953 WD - Grandpop bought new, sold to neighbor in 1965, I bought back in 2001, restored 2021; 1974 175 Gas; 1980 5050 Diesel, w/400 Loader
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2021 at 8:58pm
80r or 80t.                    MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2021 at 9:24pm
I have a 82 S, without a doubt the best mower for a WD or D series. The mower is directly to your right in front of you, you don’t ever have to turn your head. The mowing is happening just to your right. Easy off, easy on with the mounting plate still attached to your WD. Should have been AC’s most produced mower. Hay conditioner can be pulled and used at the same time. Trust me on this, its awesome.
Edited by AC720Man - 19 Oct 2021 at 9:26pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2021 at 9:30pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2021 at 9:34pm
My bother Charlie taking her for a spin. One of AC’s finest designs.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2021 at 1:22am
Any trailer mower will work,easy and quick to hook and unhook.I used a couple AC 82T trailer mowers for years cut good but some parts were getting difficult to get and the twin wheel drive does have some issues used long term.Switched to New Holland 456 trailer mowers,they cut great, very few problems, parts are easy  to find if you do need any.With any of them keep them greased up.
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2021 at 7:20pm
I would stay away from a model 7.
allisbred View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisbred Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2021 at 9:05pm
I would agree with AC720— a 82s or even the 80s is slick to operate. If the wd has the same hydraulic feature of the 45’s, you can run a crimper on delay. Not have a stiff neck from looking behind you. My father had a 82s on a 45 and went back to the 80s for some reason that I don’t recall ( the 80s was a pain to install) and the 82s just hung on the frame rail. I believe the 80s would run at 90degrees to trim branches though?
This page was generated in 0.270 seconds.
