Sickle Mower speed
sdunt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sdunt Quote  Post ReplyReply Direct Link To This Post Topic: Sickle Mower speed
    Posted: 15 May 2025 at 9:29am
Howdy, thanks for letting me join.
I just picked up a Simplicity 785 Sickle bar mower, its needs some restoration, the sellers said it had been sitting outside for 5+ years. So LOTS of PB Blaster, etc.
Now, don't shoot me, but I run JI Case garden tractors, I have a 1968 and a 1973 Loader model. My son also runs Case. Therefore, we want to adapt this sickle bar unit to fit our 3 point, and drive it with a hydraulic motor.
How fast does the drive pulley on an Allis 710/712/716  run ?  This is the sickle model with the planetary gear reduction.  The mower manual says to run the tractors engine at 3/4 throttle, so that's about 2400 RPM.
Does the PTO pulley run as engine speed?
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2025 at 10:59am
dont know the answer to your question but ji case garden tractors are cool, what models are they
Post Options Post Options   Thanks (0) Thanks(0)   Quote sdunt Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2025 at 11:27am
My 1968 is a Model 155 which is a 10 HP (kohler) "small wheel" unit
My 1973 is a Model 646 Loader tractor (16 HP Onan CCKa) with 3 Point. I also have OEM pallet forks for the loader. I use the pallet forks to move things all over my 2+ acres property. I also have a Hydraulic drive tiller for use with 646.
Plan is to use the Simplicity 785 Sickle mower on the 646 to mow ditch, and under many large trees on the property.
acken View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acken Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2025 at 7:43pm
PTO pulley is engine speed, gears inside bevel gearbox are 1 to 1 ratio.
Post Options Post Options   Thanks (0) Thanks(0)   Quote sdunt Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2025 at 6:45am
Cool, thanks for the reply. That will help me figure out what type of hydraulic motor and pulley sizes.
