Sickle Mower noise |
Page 12> |
Author | ||
NE GA Allis ![]() Bronze Level ![]() Joined: 17 Feb 2019 Location: Georgia Points: 139 |
![]() ![]() ![]() ![]() ![]() Posted: 26 Apr 2020 at 7:11pm |
Hey all, we have been running a No. 3 sickle mower to cut down our small fields. My question is, how much noise should a sickle mower make while cutting? I realize that the mower is somewhere around 60-70+ years old and does have some wear, but I just want to make sure before something catastrophic happens. Pitman is tight on both ends, hold-down fingers are adjusted to where they should be. Knife blades are old but did sharpen up fairly well. It knocks a little bit when under load but gets really loud under heavy grass loads. Is that normal? Also trying to make sure I don’t run it too fast and shake it apart. Op manual says if it shakes the tractor then your RPMs are too high.
What gear should I be able to run this in on a WD or CA? On my WD I know my ground speed is too fast cause I have 16.9x28 tires (taller than 12.4x28) and had to slip the hand clutch in first gear in thick grass but could go full first gear in light grass. On the CA first gear almost seams to slow but cuts good and second gear seams too fast. Anyone have an idea of the RPMs on the PTO that I should be able run the mower at? Thanks in advance for any help. |
Keeping Allis alive with:
2 B’s, 1 C, 6 CA’s, 2 WD’s, 1 WD45, 3 D15D’s, 1 D17 |
Sponsored Links | ||
Are the guards and ledger plates in good shape? If not and hold downs aren't adjusted properly, they will knock. MACK
I believe the guards and ledgers are in good shape. I replaced the bent guards with NOS guards. How can you tell if the ledger plates are bad?
HD6GTOM ![]() Orange Level ![]() ![]() Joined: 30 Nov 2009 Location: MADISON CO IA Points: 6627 |
Most ledger plates have serrated edges. If you look at a new guard, you can see if they are worn out. Yes in tough grass, a mower with a pitman stick has a tendency to knock a little.
Brian G. NY ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: 12194 Points: 2269 |
I guess the first thing I would do is turn the drive pulley back and forth by hand to determine where there might be some backlash. Do this at different pulley positions.
A sickle bar mower is inherently a bit noisy but when everything is adjusted correctly, it should not actually "knock".
Clay ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Udall, Kansas Points: 9900 |
When cutting wire grass, most mowers will knock. SLOW DOWN!!! If not, something on the mower will break.
Gary Burnett ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Virginia Points: 3090 |
New sickle sections will make a world of difference,correct pitman length is critical,those mowers are not made to run fast and do make a certain amount of racket.
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8644 |
...and ours broke the tube holding the pitman drive...
This is a good point.......the "register" of the cut bar is one key to good operation. When the cut bar comes to the end of it's stroke the tip of each knife should be in the exact center of a guard. On Some mowers with pitman bars the register can be adjusted. I have a Twin-Wheel mower so I have not had to deal with this. The other critical measurement when setting up a mower is giving the cut bar a certain amount of "lead". On a typical 7 foot cut bar, the outer end should run between 1-1/2" to 2" ahead of the inner end. This allows for the natural deflection of the bar when it is operating. I still say there should not be a distinct "knock" when mowing. The quietest mower I ever recall seeing was a rear mounted mower on a 2N Ford belonging to my Wife's grandad back in the 50s.
The register is correct. I think I found what most of it is. The blade assembly has a little bit of “forward and back” play (forward and back as the direction the tractor is traveling).
Is that adjusted with the wear plates? I have some new wear plates on the shelf.
I’ve got a second No.3 mower with the same problem.
Yes, that is just one more step in setting up the mower correctly. The wear plates have slotted holes so they can be moved forward to take up the play. However, they also wear out and need to be replaced periodically. You'll have this mower hummin' like a honey bee before you know it. LOL
only AC orange ![]() Orange Level Access ![]() Joined: 06 Dec 2014 Location: Eastern Indiana Points: 535 |
My best guess would be timing - pitman is too long or too short and sickle sections are not "centering" on guards as mentioned earlier!
He says in one of his posts that the register is correct.
ac fleet ![]() Orange Level ![]() Joined: 12 Jan 2014 Location: Arrowsmith, ILL Points: 2337 |
You can't mow grass with a sickle mower---they NOT designed for that abuse!---They are only for weeds and clover , alfalfa ann that sort of cutting!---AND it's a wonder you have not wrecked it already!--your mower---do as you like with it!
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 88039 |
everyone uses sickle mowers to cut the sides of the road in the country... and they are 90% grass.. If it is 2 ft tall, YEA, you got to slow down, but i cut 12- 18 inch grass pretty often.. Sometimes it clogs up and you have to stop and backup and "dump a load" then take off again.........if the grass is really thick. I have a side mower on a B... and i normally cut at 2/3 throttle... Im in no hurry.
If a sickle mower was not designed to cut a field, then what was used before the disc/rotary mower was invented?
Sixth.
Sizth.
Sugarmaker ![]() Orange Level ![]() ![]() Joined: 12 Jul 2013 Location: Albion PA Points: 8532 |
If they are tuned up[ good I would think they should cut grass pretty well? We cut 60 acres of grass/ old hay fields every year for 10 years when I was a kid. We used a 5 foot antique horse drawn type sickle bar mower hooked to the Case VAI. I got to ride the mowing machine and try to lift the blade when needed. We plugged it sometimes, or ran into a ant hill once in a while. Grandpa kept new sections in it and it purred along pretty well. We never sharpened sections just replaced them.
On clover at my Dads farm we had a 7 foot New Idea pull behind. A field of clover went down in the wind and we had to mow in one direction. About that time Dad bought the New Idea Cut-ditioner (flail chopper) and the sickle bar was never used again. Regards, Chris
Edited by Sugarmaker - 29 Apr 2020 at 8:30pm |
CrestonM ![]() Orange Level ![]() ![]() Joined: 08 Sep 2014 Location: Oklahoma Points: 8455 |
I guess me, my father, and my grandfather have been doing it all wrong for over 80 years, and never knew it!
JoeM(GA) ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Cumming,GA Points: 4823 |
yea, I hate hearing I was doing it all wrong growing up!
Allis Express North Georgia
41 WC,48 UC Cane,7-G's, Ford 345C TLB |
My mower works well, just was concerned about how loud it is.
Thanks to all for replies.
Tbone95 ![]() Orange Level Access ![]() ![]() Joined: 31 Aug 2012 Location: Michigan Points: 12208 |
Wow, so angry! What the heck did people make hay with back in the day? I know I learned how to cut hay with a sickle mower at age 10, and we certainly didn’t have pure alfalfa. |
Yeah, use artificial grass!
![]() ![]() Edited by Tbone95 - 23 Jul 2021 at 9:58am |
Ray54 ![]() Orange Level Access ![]() Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4746 |
How about we put a 3 D printer inside a big O'l plastic cow
![]() ![]() Dang it how oh how did cutting grass end up solving world hungry. ![]() ![]() ![]() ![]() Edited by Ray54 - 23 Jul 2021 at 11:54am |
Page 12> |
