Sickle Mower Help
NCAllisnut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NCAllisnut Quote  Post ReplyReply Direct Link To This Post Topic: Sickle Mower Help
    Posted: 29 Jan 2011 at 7:10pm
Had this follow me home today.  Can somone tell me what model it is, and post a picture showing how to mount it to a WD?  It supposedly came with a WD when it was purchase new, but I'm not seeing how to mount it.  "Needs Work"  seems to be an understatment, but the PTO shaft will turn.  The pitman is rotted in two.  The knives don't look so hot either.
Adam
Chris (swIA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris (swIA) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2011 at 7:27pm
It is a number 3. you are missing the bracket for attaching it to the tractor. the picture shows the early one for a WD. I have one with the later bracket. It has to brackets that mount to the final drives and has a triangular shaped mount.
Murph-NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Murph-NC Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2011 at 8:08pm
Adam, here's a photo of the other style WD mount.  Another forum member has this for sale, or did.  I'll try to find their info.
'41 C w/Woods L503 mower, #3 mower, 2-way plows for C
Post Options Post Options   Thanks (0) Thanks(0)   Quote Murph-NC Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2011 at 8:12pm
Adam, you have mail.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NCAllisnut Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2011 at 9:36pm
Thanks Murph.  I'd still like to see a picture of one of these things mounted on a WD.  I doubt I will be wanting to spend any money on this - doesn't look like it would be worth trying to fix.
Anyone need a part off of it?
Adam
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2011 at 11:47pm
Murph;that's the one we have.Kinda a bugger to hitch up.Don't forget to spin the wheels all the way out to hook up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NCAllisnut Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2011 at 10:14am
Steve,
Any way you can post some pics of the mower hitched to the tractor?
Thanks,
Adam
mnoonan-NEWI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mnoonan-NEWI Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2011 at 12:32pm
Adam, I have attached several pictures for you. Two are from my No. 3 mower attached to my CA. The others are showing (2) different ways to attach a No. 3 mower to a WD. I hope this helps.
Good luck,
Mike
Edited by mnoonan-NEWI - 30 Jan 2011 at 3:06pm
AC CA, Ferguson TO-20, Ford NAA, M-M BG, AC #3 Mower, SC Plow, PH Digger, AC 720's with Ark 700 loader & Brantly Backhoe, "Mini B" w/flathead Ford V8
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2011 at 1:57pm
Nope.It's buried in a corner of the barn.Way too much work to dig it out and hook it up for a picture.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Murph-NC Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2011 at 4:34pm
Adam, will the tire hold air?  I need a new one for ours.
ICTRCTR View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ICTRCTR Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2011 at 5:39pm
  I have a #3 parts mower if i can help.402 223 5339
This page was generated in 0.242 seconds.
