sickle mower for a G?
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Topic: sickle mower for a G?
    Posted: 20 Feb 2010 at 4:24pm
I've never had a sickle mower but a guy has one that he says is for a G. He claims it also fits a B or C with different brackets. Are the mowers the same except for the brackets or not? All I could see was a sickle sticking out of a 3 foot snow bank so I won't get a good look at it til it melts a little, I would guess it to be 5 feet long. Thanks for any input.
MilesGray (CO/KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MilesGray (CO/KS) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2010 at 5:12pm
Lonnie,
I don't know about using the sickle mower on a G, but I have two of them one for my C and one for my B, they require a different bracket for each.
Miles Gray (CO/KS)
5 1938 B's, 1940 B, 1944 WF C, 1948 NF C, Gleaner A, White Top Rotobaler, 1957 IH Golden Jubilee... I'm either a collector, or crazy!
morton(pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote morton(pa) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2010 at 5:22pm
Shouldnt need anything different to go between a B and C, unless its a later model, but as to the B/G question, I don't think they will. I think the G mower has smaller components and the brackets are more permanent, but don't quote me on that. Have any pictures? It would be easier to tell.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2010 at 5:34pm
I don't have any pictures, too much snow. He has a belly mower and a single bottom plow for a C also. I told him I would take everything when the snow melts enough to get to them. It just didn't sound right that the sickles were the same for the C and G.
Bruce Mn. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bruce Mn. Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2010 at 7:55pm
C & G  mowers are not the same. alot of components are the same but not the whole mower . the G mower is run off the v pully on the left side of tractor while the C runs off a v pulley on the pto out the rear. mounts are also different.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2010 at 8:23am
Is the mower for the B&C 5' or 6'?  I've run a 7' with a C, no problem.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2010 at 8:37am
He said the belly mower is a 6 foot, but that was completely buried in the snow, I never actually saw it. He says he used the belly mower until 2 years ago when he got a mower for his big tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2010 at 9:32am
The one for the G is 5'. I'v got one for my G.
Dusty
Cal View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cal Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2010 at 12:05pm
The G mower will have a foot operated lever to engage or disengage the belt , that  should be the most obvious difference besides the brackets and belt cifiguration. There should be some B mower pictures on here to help you Identify what it is. Cal in Ct.
