sickle bar model question |
Post Reply |
The Hooker
Bronze Level Joined: 31 Mar 2016 Location: ORE-e-GUN Points: 44 |
Posted: 29 Apr 2019 at 4:28pm |
Dakota Dave
Orange Level Joined: 12 Sep 2009 Location: ND Points: 3895 |
Looks like a model 80 to me that is a WD 45 mount laying in the picture. I don't see the right axle attachment point for the balance spring.
The Hooker
I am not familiar with the right axle attachment point for the balance spring. here is another picture. Is it here?
DiyDave
Orange Level Access Joined: 11 Sep 2009 Location: Gambrills, MD Points: 50668 |
Pull the drive bushing out, 80's has a concave shape or dome type bushing, 82 would have a serrated looking bushing, that engages with a similar surface, on the knife head...
Dakota Dave
Nope that long spring going foward withe the clevis end attaches to a small bracket that bolts to the top of the right axle. It's usually still on the tractor. That round bar with the brackets pins on in place of the drawbar bail. And the h looking piece with the two v mouth cuts goes on the round pin ends that should be attached to the front of the main mower frame. The mower head is currently in the break away position. You'll have to let the bar down and back up when it's mounted till the beark away over centers. The missing bracket is fairly easy to fabracate. The h shaped part looks like it was cut off and it'll need to be welded back together
Edited by Dakota Dave - 29 Apr 2019 at 6:08pm |
The Hooker
My WD45 is a factory henry loader and is bareback w/no lift bars or rams. Was the 80 model sold to fit a D14? Thanks for your help |
Gary Burnett
Orange Level Access Joined: 11 Sep 2009 Location: Virginia Points: 2854 |
The mowers are the same for different tractors the brackets are different.Hope you are a good welder.
The Hooker
What are the chances of getting pictures /measurements of a model 80 for a S/C ? Thanks again guys
MACK
It is a 80R. I have a axel bracket I would sell. MACK
AaronSEIA
Orange Level Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2534 |
Its an 80R, but the front 3' of the frame has been cut off it looks like. I've got a good one I'm selling if you are looking. AaronSEIA
Brian G. NY
Orange Level Joined: 12 Sep 2009 Location: 12194 Points: 2199 |
The front part of the mower frame is there, just not attached....you can
see it in the lower RH side of the picture.
The Hooker
You Sir have a very good eye, seeing pictures I haven't posted the pieces are there so some welding is in order. looks like someone got hung up in it and tripped the break away and they cut the ears to get loose
JK in Pa
Bronze Level Joined: 12 Sep 2009 Location: Dushore, Pa. Points: 159 |
Looks like possibly someone was thinking about converting it to three point hitch?
Tim NH
Orange Level Access Joined: 16 Oct 2012 Location: Lancaster NH Points: 1065 |
I have a 80R on my D14. I have another bracket to mount it on the WD. In the first picture you can see the channel steel welded on the left of the mower is pointing down. The other one is straight ahead. They both should be pointing straight ahead. You can see unequal distance between the two pipes in the frame. If thats whats going on you'll be busy fixing it.
Tim
Post Reply | |
