Shuttle gear for I40
pineyjd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pineyjd Quote  Post ReplyReply Direct Link To This Post Topic: Shuttle gear for I40
    Posted: 09 Jun 2011 at 3:59am
Where can I buy gears for my I 40 transmission ??,kicks out of forward /reverse on shuttle.
I can hold my foot on lever & works fine.
Also need diagram of transmission
Kipn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kipn Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2011 at 9:27am
I believe argoparts dot com is still up for pictures under the D15. Many sponsors on this site should be able to hook you up with the parts.
1961 H3
Post Options Post Options   Thanks (0) Thanks(0)   Quote pineyjd Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2011 at 5:18am
Tried argoparts,could not find any info,thanks for info. going to use till winter & then take apart,I can hold it in gear with my foot as it only kicks out occ. under load ??
D-17_Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2011 at 10:15pm
If it's the shuttle lever that kicks back to neutral then you likely only need to rebuild the wet clutch assembly. Same as the HI-LOW on any ag version tractor. If it still pulls good it may only be the cams on the follower or the tips worn off the shift yoke. Remove the side plate and look inside for worn edges. The yoke can be replaced without splitting the tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2011 at 10:18pm
I forgot you were talking about an I-40, not the I-60 which is based on a D-15. Same internal design but I'm not sure how the wet clutch is accessed.
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2011 at 8:10am
Here are scans from my I40/I400 Service Manual;
Edited by JoeO(CMO) - 07 Jul 2011 at 8:06pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote pineyjd Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2011 at 3:44pm
Thanks for info,my book do not show those diagrams
