Shuttle Clutch ? |
Post Reply |
FREEDGUY
Orange Level Access Joined: 15 Apr 2017 Location: South West Mich Points: 5391 |
Posted: 02 Feb 2021 at 6:06pm |
Can someone explain what it is on a tractor ? Is it similar to a hydro tranny on a combine ? There is a post on AT about a 170 with it today and I've read about other tractors with this feature. Thanks
nickia
Orange Level Joined: 11 Sep 2009 Location: alden iowa Points: 762 |
my backhoe has a shuttle shift on it you put it in a selected gear and then there is a big "stick" on the left had side that you push forward for forward motion and pull back for reverse movement. very handy for use on a loader tractor no clutching going from forward to reverse
AC720Man
Orange Level Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 4668 |
Changes pto speed...850rpm if I remember correctly
Kenny L.
Orange Level Access Joined: 12 Sep 2009 Location: NEIOWA Points: 1225 |
I've it on my D-15 that has a 415 allis loader on it and works like Nick said and my pto is 540 rpm.
Dakota Dave
Orange Level Joined: 12 Sep 2009 Location: ND Points: 3895 |
Not even remotely similar to a hydro. Instead of a two speed power director it has two same speeds one foward one reverse. When you push the lever foward would be low on a regular tractor it goes foward whatever gear the transmition determine your speed. Pull back to center on the stick tractor stops both power director clutches are disengaged. Pull back on the lever engages what would be high clutch but instead power flow is reversed so now your going backwards in whatever gear the transmition is in.
Gary
Orange Level Access Joined: 13 Sep 2009 Location: Peterborough,On Points: 5179 |
Dave What you describe is bassawkards for any D Series I have driven ( 14, 15, 17) Power Director Forward for High Range, Backward for Low Range. G |
FREEDGUY
Thanks for the description of HOW it works and makes sense of the replies that Doc gave to the guy about PTO (dual) speeds .
Dakota Dave
Gary I'm sure your correct Im sorry I haven't drove one since the 1970's.
Alex09(WI)
Orange Level Joined: 15 Mar 2012 Location: CECIL WI Points: 1699 |
I plan on installing a shuttle clutch torque tube out of a I60 into my D15 II and it would be awesome if the PTO still was normal 540. I read somewhere that the shuttle gears change the PTO speed.
www.awtractor.com
A&W TRACTOR 920-598-1287 KEEPING ALLIS-CHALMERS IN THE FIELDS THROUGH THE 21ST CENTURY |
nickia
how fast is the pto on a wd or a wd45? im sure they are slightly faster than 540? any one?
Orange Level Access Joined: 12 Sep 2009 Points: 19595 |
Any A-C with a shuttle clutch has a faster than normal PTO. Memory tells me 800 to 850 RPM at full throttle. A WD45 or D-17 is normally 650 ish.
Calvin Schmidt
Orange Level Joined: 11 Sep 2009 Location: Ontario Can. Points: 4515 |
I have an I600 with a shuttle. The PTO has the 1000 rpm spline so it must be close. The DR. has it right. The PTO on my H3 crawler with a shuttle is 540 PTO. It has a rear gear box to correct the PTO to 540 unlike the tractors .
Post Reply | |
