Shuttle Clutch One-Seventy is born |
Post Reply |
Bret (OH)
Silver Level Joined: 15 Sep 2009 Location: Blanchester, OH Points: 347 |
Thanks(1)
Posted: 16 Jul 2020 at 8:51am |
It left West Allis in 1969 as a Power Director, and was re-born in Blanchester as a Shuttle Clutch in 2020.
The search for the correct parts started months ago and I finally found enough OEM parts to put it together. I was not able to find an OEM oil cooler, so I went with an aftermarket from Surplus Center. I was able to locate a set of NOS cooler lines (they still had the Allis Inventory tags wired to them). There were 4 lines in the set, but one was labeled incorrectly so I couldn't use it, but the long lines, and one of the shorter front lines were correct. I had to make a couple shorter lines to extend to the aftermarket cooler. The transmission clutch shaft gear was the most difficult to locate as it is unique to the D-17/170, some of the other gears were used in other things so are more available. One spacer on the PTO gear shaft I was unable to locate so I machined it from hardened steel. While it was split, I also removed the Button Clutch and replaced it with a fiber disc and re-man pressure plate so the foot clutch would be less "grabby". |
Orange Level Access Joined: 12 Sep 2009 Points: 19609 |
A lot of work for sure !! Awfully nice looking tractor to be on a loader. it wouldn't stay nice for very long on a dairy farm...……...
ranger43
Bronze Level Joined: 09 Jun 2019 Location: Huntingburg Points: 147 |
really cool...nice looking tractor
CTuckerNWIL
Orange Level Joined: 11 Sep 2009 Location: NW Illinois Points: 22810 |
It looks like a handy rig Butch. Purdy too!
Brian F(IL)
Orange Level Access Joined: 14 Sep 2009 Location: Paxton, IL Points: 2691 |
We had a similar forklift and boom set-up on our loader at the dealership back in the '70's. Had it mounted on a One-Ninety gas. Loader frame was probably similar. Was pretty easy to move from using the forks to using the boom.
Your set-up should prove to be very handy.
DSeries4
Orange Level Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7206 |
That worked out real good! That will save a lot of clutching. Sharp looking tractor too! |
Alex09(WI)
Orange Level Joined: 15 Mar 2012 Location: CECIL WI Points: 1699 |
Hey Bret! Glad to see you got it together! Sure makes a nice loader tractor! I plan on doing the same to a D15II one day
www.awtractor.com
A&W TRACTOR 920-598-1287 KEEPING ALLIS-CHALMERS IN THE FIELDS THROUGH THE 21ST CENTURY |
Post Reply | |
