Shuttle clutch on D15? |
Post Reply |
elec
Bronze Level Joined: 23 Nov 2020 Location: mi Points: 84 |
Posted: 09 May 2021 at 11:36am |
Anyone know if it's possible to put a shuttle clutch on a D15? I bought a D15 industrial, shuttle works good but tractor has alot of problems so I'm wondering if I can put the shuttle on my D15 I'll instead. I'd so, how hard is it to do?
Thanks |
SteveM C/IL
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8035 |
Not so much "hard" as is alot of work. If you use your PTO don't do it. I believe it changes PTO speed gearing.
DSeries4
Orange Level Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7206 |
Steve is correct. It spins the PTO much faster - around 800 rpm. Way too fast for an implement rated for 540 rpm. If you have all the parts you need, it would be a pretty straight forward job. Just don't use the PTO!
jaybmiller
Orange Level Access Joined: 12 Sep 2009 Location: Greensville,Ont Points: 21598 |
man, I hate to think of the 'fun' tearing ONE D-15 apart but TWO ???? Well, I suppose you'd get REAL good by the end of the month........ problem for me would be are those 'extra' parts really extras or did I forget to install them ?..... as for the PTO speed, it's maybe 50% higher , so could you run the RPMs 30% slower ? Anyone try that or would the tractor 'bog down' ? jes curious.....
elec
Thank you. Will probably start the project this winter.
Bret (OH)
Silver Level Joined: 15 Sep 2009 Location: Blanchester, OH Points: 347 |
All the parts will interchange. The difficulty will be obtaining the correct thickness of snap rings to properly set the preload on the bearings.
I suggest having a Allis repair manual for reference. The parts books are available at agcopartsbooks.com. |
Post Reply | |
