Showing a Sickle bar
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Topic: Showing a Sickle bar
    Posted: 05 Oct 2010 at 11:24am
I was going to take my B with the Belly Sickle Mower to a heritage show this weekend and my brother told me I should take it off, or at least remove the sickle so that I won't be liable if someone hurts themselves.
Should I be concerned? or just place something over the blade area to keep people out of it?
Charlie
KY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KY Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2010 at 11:25am
Alot of folks put styrofoam pipe insulation over them. the kind that is split in half.
split51 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote split51 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2010 at 11:25am
 I have seen them at shows  covered in cardboard or plexiglass to keep people from getting to the blades.
1929 20-35 sn17662
B1 w/snow blade
B10 w/sickle mower
B110 w/mower deck
B110 w/tiller
B112 w/grader blade
B210 w/plo
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2010 at 11:28am
2" PVC pipe with a 1.5"slot cut the entire length with a skilsaw works really well. Held on by a couple of bungee cords
firebrick43 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote firebrick43 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2010 at 11:55am
Our club uses pieces of black plastic 4-6" field tile sliced on one side.  Just cut one side, don't really need to slot it like pvc.  They will stay in place without any help if you have regular rock guards and not stub guards.  If fact they can be a pain to remove.
Two 1x4's with bolts clamping them together work as well.
The pipe insulation and cardboard is a no no.  Any one, especially running kids hit it, the points will go right though the foam or cardboard.  Have seen it happen.
Smaller PVC pipes protect people from the points but they still can get their grubby little fingers into the knife.
The boards or drain tile covers the whole shebang.  If you use something to cover just the points, remove the knife.
The plexiglass is a novel idea, protection but still allows for people to see how it works.  I imagine quite expensive however.
Edited by firebrick43 - 05 Oct 2010 at 11:57am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2010 at 12:55pm
I've seen the PVC field tile over them and it looked like that was about as dummy proof as anything could be to me.
OrangePowerGA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OrangePowerGA Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2010 at 12:59pm
I have seen plexiglass used at shows.  IMO it is the best way to go.  It keeps people safe and still allows them to see how it works.
1946WP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1946WP Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2010 at 9:13am
I've seen one made of wood & stained to match the seperator board . looked really sharp.
JohnCinMd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCinMd Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2010 at 9:34am
Let me play devil's advocate here for a minute. What about all the other stuff that can hurt someone that's not covered up. Everything that we show has some inherent danger. People should know that, gee, it's a sickle knife, it must be sharp. The step on that tractor is wet, it might be slippery. It's a shame that society is so litigious that we have to protect people from themselves.
Dave Richards (WV) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Richards (WV) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2010 at 9:40am
Make sure the blade is at the bottom of it's travel.  Have seen one up right and the counter weight pulley rolls over at the wrong moment and the blade falls.
Good View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Good Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2010 at 10:47am
I'am kinda with JohnC things are getting out of hand. I don't think I've seen any covered up around here. I think the liable one is the people putting on the show. But I can't argue against someone being safe.It does take away from the looks but at least if a little kid runs into he will have both eyes to enjoy the show.
B212,716,two 314H's,WC,WD,D19,190XT
Post Options Post Options   Thanks (0) Thanks(0)   Quote split51 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2010 at 12:19pm
This is a little O/T but I agree with JohnC, people do not think when around this equipment. I have been to several shows and seen parents letting their kids just crawl all over other peoples equipment. Not only is it dangerous, some of these tractors, etc are restored to a show car quality.  At Goto in Madison last year, a lady was letting her kids crawl on a beautiful restored U I believe is owned by the Grahams. I walked over to her and kindly told her I didnt think the owner would appreciate the kids on the fenders and hood. She had them get off of the tractor but acted like it was no big deal, its just an old tractor.
Edited by split51 - 06 Oct 2010 at 12:20pm
1929 20-35 sn17662
B1 w/snow blade
B10 w/sickle mower
B110 w/mower deck
B110 w/tiller
B112 w/grader blade
B210 w/plo
Rick of HopeIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2010 at 5:55pm
Can't blame folks for not realizing the sickle bar is dangerous.  Lots of people are at shows to learn about such things, that is just part of it.  I don't like seeing implements and buckets left raised either.  Accidents are sad,  I have been hurt plenty, usually after doing something dumb.
Chris(WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris(WA) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2010 at 7:47pm
I got a piece of ORANGE 6" fire hose, slit one side and slipped it over the guards and sections. Used black bungie balls to keep it in place. Looks pretty darn good.
Washingtonian by choice, Wisconsin Farmboy by the grace of God!
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2010 at 7:55pm
Forget about the litigation part of it. It should be safe. How would you feel if a 3 year old curious kid got seriously hurt?
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCinMd Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2010 at 8:09pm
Stan, you're absolutely right. But, there are so many other places where someone could get hurt that aren't covered. Oh well, I apologise to Charlie for jumping in here bringing up something that really doesn't have anything to do with what he was asking.
Dnoym N. S. Can. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dnoym N. S. Can. Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2010 at 8:18pm
like the guy`s are telling you
this is what i used when i put
mine on display sorry about
the color HTH
  B:-)    Dnoym
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dnoym N. S. Can. Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2010 at 8:33pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1946WP Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2010 at 10:10pm
it's sad that our society has gotten like it is but there are many people that don't respect others property or know the dangers of it' It isn't only the younger people.last year at hutch some elderly man sat there & watched his grand children ,I believe, climb up on daves super restored A. I walked over and told them to get off, the old guy looked at me like what will they hurt? I looked over at him & said these tractors are here to be looked at, not to be played on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2010 at 7:14am
To many what if's to worry about....
I'm taking the mower off anyway as they are now having a pull on Sunday that I want to do.
Thanks for your input.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2010 at 8:28am
I agree Completely
Charlie
