Shop Talk |
Page <1 555657 |
Sugarmaker ![]() Orange Level ![]() ![]() Joined: 12 Jul 2013 Location: Albion PA Points: 8517 |
Folks,
This small change to allow some actual work area near the lift has been wonderful! We have the front of the Comet apart and it is being reassembled. The work surfaces provide the space for new and old parts and help that antique car project to move along easily. Thanks for checking in on me. Regards, Chris and Cheryl
GSTROM99 ![]() Silver Level ![]() ![]() Joined: 12 Dec 2020 Location: Greene, IA Points: 246 |
What are you doing to the Comet? |
GSTROM99,
Putting new front suspension, steering components, and disc brakes with dual master cylinder on it. 60 years, it's time for a upgrade!. Just set it down on the new coils and the front is 2 inches higher than it was. Car is level with the air shocks in the back now. Still have the master cylinder to install, and a rear brake hose. Then can start to bleed the system. Should be fun! Then to the alignment shop! Regards, Chris and Cheryl
Disc brakes, and dual master are great upgrades. Power or manual? Either way, being able to stop when needed is a pretty good plan.
Edited by GSTROM99 - 21 Sep 2024 at 7:19am |
Gstrom99, Folks,
Well as I pulled the rear axles to replace the seals I found the old wheel cylinders were frozen and or really rusty. So new NAPA wheel cylinders were installed on the rear. Bleed the rear brakes again. Checked the vent of the rear end while we were in there. Several test rides: The brakes work really well with good pedal, not power for sure but confident of the stopping ability. Drivability is much better! Maybe 80 % better. Can't wait to see if the alignment makes additional improvements. Now thinking there rear springs may need some help as its now a little soft in the rear. Regards, Chris and Cheryl
Edited by Sugarmaker - 27 Sep 2024 at 7:27pm |
Alberta Phil ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: Alberta, Canada Points: 3919 |
Hey Chris. I like the pic of the "job site boss" makin' sure it's done right! LOL
Phil,
We are so lucky to have this sweet woman in our lives! She doesn't comment much at this point, but loves to go see what's going on our projects! I am learning things to do to help us get through the day and have fun too. We took the 65 Comet to breakfast, then took the 32 truck to the nearby job site to help on the building. Our lives have changed a lot. I miss Cheryl's cooking!! Regards, Chris and Cheryl Edited by Sugarmaker - 06 Oct 2024 at 6:54pm |
tadams(OH) ![]() Orange Level Access ![]() ![]() Joined: 17 Sep 2009 Location: Jeromesville, O Points: 10902 |
Looking nice
ac hunter ![]() Orange Level ![]() ![]() Joined: 05 Jan 2011 Location: OHIO Points: 1051 |
Hey Chris,
Looks like a lot of empty space in there. You could offer to help fill it up with some of your projects. Good looking shop.
Guys,
I am hoping his WD tractor will go down there. That may leave some room for the CA if it ever gets done. They have the roof on. Now the walls. Regards, Chris and Cheryl
200Tom1 ![]() Orange Level ![]() ![]() Joined: 03 Jun 2019 Location: Iowa Points: 1232 |
I agree with Brian, spray foam it for insulation. It makes the building tighter.
Tom, Folks,
I think he is going to stud the inside walls and put vertical batting in them. He plans to have blow in insulation above the steel ceiling. Have been trying to talk him into pex in the floor but he is dead set against it. Boy Cheryl and I are really enjoying the warmth in our shop! Worked with his building crew to put up some steel on the west wall. Rain and wind and mud today! Regards, Chris and Cheryl
Edited by Sugarmaker - 23 Nov 2024 at 7:26pm |
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 87819 |
Chris, what is the point of the recessed garage door ? .... Just need an entrance porch / out of the weather ?
Steve, folks,
The rear garage overhead will be where the bikes, four wheelers, and side by side will go in and out most of the time. Nic has four boys between 12 and 6! The corner concrete will be a separate pour from the floor. The undercover area will be to sit out of the sun in the evening. Morning coffee there too. Nice place to sight in the guns or bows, into the back yard. Or watch the boys on the dirt track or at the pond in the back field too. Might have a cold frosty adult beverage from there too? Siding is coming along nicely. I helped a couple hours this weekend. Things like holding the dumb end of the tape or picking up the job site. Regards, Chris and Cheryl
Edited by Sugarmaker - 25 Nov 2024 at 8:15pm |
Allis folks,
Weather has turned to winter mode in our area. Checked all the tractors and the WD45 needed upgrade in antifreeze, others were all good. The D14 was called on to push snow today. About 2 feet of white stuff, sometimes called pretty by some Allis folks, needed to be shoved this way and that! I was proud of the D14 with its high lift, snow plow and bull chains. Ruby had fun too. After the drive was cleared I had the 32 out, just to move it out of the lift bay. Shop is a comfortable 66 F with the kitchen at 68 for Cheryl and I to sit and drink tea and watch TV. Temps outside are around 25 F. Enjoying the radiant heat system in the shop floor! We had Thanksgiving in the shop for the first time. About 20 family members enjoyed eating and visiting. The kids loved it! We have much to be thankful for! Cheryl and I are now the old folks, not sure how that happened so quickly? Our newest Great granddaughter Cassie was very comfortable in her seat on the floor. Regards, Chris and Cheryl
Edited by Sugarmaker - 01 Dec 2024 at 12:42am |
plummerscarin ![]() Orange Level Access ![]() Joined: 22 Jun 2015 Location: ia Points: 3912 |
Looks like a very comfortable space indeed!
It's cold enough here but no snow. Tho we've seen some flurries. The forklift i got a while back will also need an antifreeze service since it now sits in a cold storage room. Yesterday I wanted to use it but it refused to fire. Got spark,no start. Only difference between yesterday and 4 days ago is a 20 degree temperature drop Edited by plummerscarin - 01 Dec 2024 at 6:11am |
Allis folks,
The old brain still thinks I am young and can do things! On the way to the house to check on Cheryl I saw a couple deer grazing in the bean field in back of our house. Hunting mode kicked in and I dug out the 30.06 and a couple shells. Walked out behind the house and found a good rest in a ash tree. Humm? Touched one off, holding 6 inches above its back. Saw a deer run in the woods and one continued to eat. Went and got some hunting boots and clothes and trudged back there. I got within 100 yards and finally the grazing deer bounded away. Expecting to track a doe into the woods. I was surprised to see a ear sticking out of the snow. As a lot of you know that's when the work starts! So a tag is filled and the meat will go to my Grandson Mike who has been helping me work on my F250. Our Great Grandson Rhett got a real nice doe last night. He was so happy. He did a really good job. Regards, Chris and Cheryl
Allis guys,
Its been a while for a update on this thread. Some of the things we have done in the shop. This place has been a real good thing for Cheryl and I to spend time in a warm comfortable kitchen that I can step into a adjoining warm shop area and do some work on my many toys. The work area has been used to help with projects like replace the rear springs on the Comet twice. Replace rear springs on Johns 48 Ford. get started on the Allis CA and complete it (almost ) recently. We added a full size used fridge to the kitchen. Very nice addition! Hosted our 22nd annual Maple weekend (Taste and Tour) in mid March. Set up a temp paint booth inside the building for the CA parts. Used the Jib crane to assist in the assembly of the CA also. We hosted several dinners for our Antique AACA car club with 30 folks attending. Our son Adam and his girlfriend have visited several times and the loft has worked very well for them to relax. Our grandson has been finishing details in his shop, large portion is his business building and office, man cave and young folks hang out. Plus motorcycle shop for his boys too! Very nice! He has also taken his Allis WD home. Gives me a little more room in the mini tractor storage area too. Weather is getting cooler and the shop floor will be kicking in its heat in a few weeks! Hope things are good in Orange Land! Regards, Chris and Cheryl
Edited by Sugarmaker - 03 Sep 2025 at 8:39pm |
DMiller ![]() Orange Level Access ![]() Joined: 14 Sep 2009 Location: Hermann, Mo Points: 33967 |
Really need to expand on inside storage here, keep my own toys warm and dry, less sun baking.
You are a inspiration!! |
Page <1 555657 |
