Shop Talk
 Post Reply Post Reply Page  <1 555657
 Rating: Topic Rating: 3 Votes, Average 5.00  Topic Search Topic Search  Topic Options Topic Options
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2024 at 8:48pm
Folks,
 This small change to allow some actual work area near the lift has been wonderful! We have the front of the Comet apart and it is being reassembled. The work surfaces provide the space for new and old parts and help that antique car project to move along easily.
Thanks for checking in on me.
 Chris and Cheryl
GSTROM99 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GSTROM99 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2024 at 7:00am
What are you doing to the Comet?
Post Options Post Options   Thanks (1) Thanks(1)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2024 at 1:43am
GSTROM99,
Putting new front suspension, steering components, and disc brakes with dual master cylinder on it. 60 years, it's time for a upgrade!. Just set it down on the new coils and the front is 2 inches higher than it was. Car is level with the air shocks in the back now. Still have the master cylinder to install, and a rear brake hose. Then can start to bleed the system. Should be fun! Then to the alignment shop!
 Chris and Cheryl
Post Options Post Options   Thanks (0) Thanks(0)   Quote GSTROM99 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2024 at 7:18am
Disc brakes, and dual master are great upgrades.  Power or manual?
Either way, being able to stop when needed is a pretty good plan.
Edited by GSTROM99 - 21 Sep 2024 at 7:19am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2024 at 7:26pm
Gstrom99, Folks,
Well as I pulled the rear axles to replace the seals I found the old wheel cylinders were frozen and or really rusty. So new NAPA wheel cylinders were installed on the rear. Bleed the rear brakes again. Checked the vent of the rear end while we were in there.
Several test rides: The brakes work really well with good pedal, not power for sure but confident of the stopping ability. Drivability is much better! Maybe 80 % better. Can't wait to see if the alignment makes additional improvements.
Now thinking there rear springs may need some help as its now a little soft in the rear.
 Chris and Cheryl
Edited by Sugarmaker - 27 Sep 2024 at 7:27pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2024 at 5:41pm
Allis folks,
Grandson has started his new shop:
My job: pick up tools, get in the way, make comments, consume beverages!
 Chris and Cheryl
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2024 at 5:44pm
Hey Chris.  I like the pic of the "job site boss" makin' sure it's done right!  LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2024 at 6:52pm
Phil,
 We are so lucky to have this sweet woman in our lives!
She doesn't comment much at this point, but loves to go see what's going on our projects!
I am learning things to do to help us get through the day and have fun too.
We took the 65 Comet to breakfast, then took the 32 truck to the nearby job site to help on the building. Our lives have changed a lot. I miss Cheryl's cooking!!
 Chris and Cheryl
Edited by Sugarmaker - 06 Oct 2024 at 6:54pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2024 at 9:13pm
Guys,
Update on grandson Nic's shop.
Roof is on. Doors are in place!
 Chris and Cheryl
Edited by Sugarmaker - 17 Nov 2024 at 9:14pm
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2024 at 12:38pm
Looking nice
ac hunter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac hunter Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2024 at 1:21pm
Hey Chris,
     Looks like a lot of empty space in there. You could offer to help fill it up with some of your projects. Good looking shop.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2024 at 8:35am
Guys,
 I am hoping his WD tractor will go down there. That may leave some room for the CA if it ever gets done.
They have the roof on. Now the walls.
 Chris and Cheryl
200Tom1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200Tom1 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2024 at 8:17pm
I agree with Brian, spray foam it for insulation. It makes the building tighter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2024 at 7:23pm
Tom, Folks,
 I think he is going to stud the inside walls and put vertical batting in them. He plans to have blow in insulation above the steel ceiling.
Have been trying to talk him into pex in the floor but he is dead set against it. Boy Cheryl and I are really enjoying the warmth in our shop!
Worked with his building crew to put up some steel on the west wall. Rain and wind and mud today!
 Chris and Cheryl
Edited by Sugarmaker - 23 Nov 2024 at 7:26pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2024 at 7:43pm
Chris, what is the point of the recessed garage door ? .... Just need an entrance porch / out of the weather   ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 7 hours 42 minutes ago at 8:11pm
Steve, folks,
The rear garage overhead will be where the bikes, four wheelers, and side by side will go in and out most of the time. Nic has four boys between 12 and 6! The corner concrete will be a separate pour from the floor. The undercover area will be to sit out of the sun in the evening. Morning coffee there too. Nice place to sight in the guns or bows, into the back yard. Or watch the boys on the dirt track or at the pond in the back field too. Might have a cold frosty adult beverage from there too?
Siding is coming along nicely. I helped a couple hours this weekend. Things like holding the dumb end of the tape or picking up the job site.
Chris and Cheryl
Edited by Sugarmaker - 7 hours 38 minutes ago at 8:15pm
This page was generated in 0.173 seconds.
