Shop heat |
Steve g
Topic: Shop heatPosted: 18 Sep 2021 at 7:06pm |
Taking input on fuel oil furnace for my Shop heater .just picked up an aluminum 150 gallon semi truck fuel tank now I just got to decide what furnace to install many options are out there.
Joined: 11 Sep 2009 Location: illinois Points: 89571 |
Posted: 18 Sep 2021 at 7:37pm |
are you talking about the "NEW" furnaces in the 80- 95% efficiency range ? .... Yes, many manufacturers. ........ Similar to NG or propane style... Base line in the $800 range... high eff up to $2000. ??
Dusty MI
Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5061 |
Posted: 18 Sep 2021 at 9:08pm |
I've got a used furnace I'd like to get rid of. Set up for LP now can be changed to Nat. gas without much trouble. Could be set-up for oil, but would take a bit to do that.
Dakota Dave
Posted: 18 Sep 2021 at 9:54pm |
Use propane and put up a radiant tube heater outside vented. If you don't have the overhead room get cube heater and put in one corner pointed toward the opposite corn
Brian Jasper co. Ia
Posted: 18 Sep 2021 at 10:05pm |
Something else to consider is doing a mini split system. I have one and it’s great. Very efficient to operate and it provides A/C in the summer. There are DIY systems from Mr. Cool that just about anyone can install themselves.
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24943 |
Posted: 19 Sep 2021 at 6:18am |
can you build a 'furnace room' onto the shop ? The 7by16 'annex' I put on has gas furnace, air compressor, steel storage and chemicals,spare air hoses,tractor parts,small tire tubes and a Chevy pickup driveshaft( I drive a Ford.......) edit... forgot to say there's just 2 holes in the common wall, one at floor level for the 'cold air return', other up top for the heat to get into the 'shop'. I have a 'primary' filter on the cold air return, in the shop. It gets most of the crud before the real furnace filter does,also a lot easier to change. No ducting in the shop. It's the 24by25 garage the wife USED to store her car in. Only takes 10-15 to get toasty warm.
Edited by jaybmiller - 20 Sep 2021 at 6:11am |
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35082 |
Posted: 20 Sep 2021 at 4:34am |
I agree with Jay, put it in a annex side build, if do ANY Paint work want NO Flames anywhere near to the work area, piping in heat is a better option. My actual workshop area is NOT heated or cooled just insulated well. When or IF I decide to heat it will either be Heat Pump type or within a second structure and heated air piped in.
