Shop ceiling choice advice?
GSTROM99 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GSTROM99 Quote  Post ReplyReply Direct Link To This Post Topic: Shop ceiling choice advice?
    Posted: 19 Feb 2021 at 8:05am
I'm doing all the normal research for my upcoming shop build.  I'd been planning on using steel panels for the interior ceiling, but I just saw these PVC panels available through Menard's:
https://www.menards.com/main/building-materials/pole-barn-post-frame-materials/steel-panels/pro-tuf-interior-pvc-liner-panel/1558720/building-materials/pole-barn-post-frame-materials/steel-panels/pro-tuf-interior-pvc-liner-panel/1558723/building-materials/pole-barn-post-frame-materials/steel-panels/pro-tuf-interior-pvc-liner-panel/1558731/p-1535437692002.htm
The PVC panels are slightly cheaper, and weigh about 1/5 of the steel panels.  I'm leaning on going with these.
Anyone have experience or opinions on the PVC option?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2021 at 9:57am
never seen them before......... but looks REAL INTERESTING for a shop wall or ceiling !
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2021 at 10:56am
gives SugarChris yet another option to think about !!!!
I like the less weight aspect....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2021 at 11:01am
Dang you guys! I have my steel for the ceiling already but this stuff looks very interesting too. Thanks for the link. We have a Menards about a hour away in Ohio.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2021 at 12:36pm
For an 8' sheet that's all you can get in the poly a dura panel is 37 cents Cheeper and made of steel. I had poly panels for trailer skirting they did not hold up well. A lawn mower Rock whent rite through it shattered a piece out.I put the dura panels up on both my walls and cieling use the white it reflects lights wonderfully. I've backed a truck hitch thru the wall at the farm the steel is easy to repair just loosen it up bang it back our and stick a piece of gorilla tape on the back and screw it back in place. I put the galvanized ones up in my barn but they cause uneven lighting.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2021 at 12:55pm
Dave, it says the poly is to be used INSIDE for ceiling and walls... I think being very LIGHT it might be a good ceiling cover.... and they list 8 , 12, 16, 20 ft lengths.
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2021 at 1:10pm
If it's lighter weight wouldn't it sag between the joists!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2021 at 8:57pm
I'll keep my white steel (not so white after 35yrs) Never up there but if I missed my step, I'd still be up there not on the concrete floor
Post Options Post Options   Thanks (0) Thanks(0)   Quote GSTROM99 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2021 at 9:27am
Yeah, I've now decided to go white steel too.  If the PCV was WAY cheaper, I would be more likely to try it.  The brochure even says change in pigment (color) is expected and (only) has a 5 year warranty from cracking, etc...  I don't want to have to re-do this.  Ever.
modirt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote modirt Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2021 at 3:13pm
So I'm finishing out a 12' x 24' enclosed shop inside the barn. It was roughed in when I got here, so has ceiling joists 16" on center. They run the 12' width and have about a 2:1 pitch.
Walls and ceiling insulation is glass batts. Walls are covered with OSB. Was going to do OSB ceiling too, but now leaning towards doing this PVC or metal. PVC might not sweat.....and joists above are decked too, so not going to step on it.
Would a person run that the long way, the short way or doesn't matter?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2021 at 3:31pm
I put reflected across my rafter bottom cords before putting the steel on blew in R 30 fiberglass above my shop stays warm in the winter and cool in the summer I have adequate attic ventilation so have zero condensation in a steel pole building.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2021 at 6:07pm
re: Would a person run that the long way, the short way or doesn't matter?
normally you run the 'next layer' of material 90* from the 'last layer'...
 consider a wall(easier for me), studs (1st layer) are vertical, so drywall (next layer) goes on horizontal.If you then added panelling, it'd go vertical.....
clear as mud ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2021 at 9:32pm
modirt... normally you would run perpendicular to the joists... You have 12 ft joists on 16 inch centers and enough length for 24 ft.... You would buy two 12 ft pieces and  put one on the end of the other to run 24 ft long... Your panels would be 36 inch, so you use 4 wide to fill the 12 ft room. ..... i did a little reading on the pvc panels and one thing is they act like siding on a house.. If it goes from zero to 100 degrees, the panels STRETCH and will bind on the screws... Some of the panels they recommend not squeezing the screws down REAL TIGHT... of course if you are inside and the temp only varies 20-30 degrees, probably not that important.
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2021 at 3:40pm
The 2- 12' panels doesn't allow for much overlap WinkWink !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2021 at 4:23pm
dont need much... not raining inside the shop !  LOL
PVC panels are actually 12' 2" to allow for overlap.
Edited by steve(ill) - 21 Feb 2021 at 4:25pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2021 at 4:34pm
I was thinking of the "fastening" aspect Wink.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2021 at 4:43pm
why not ?  you got a 24 ft room and two 12' 2" panels ... 4 inch overlap !
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2021 at 5:02pm
Your original post said NOTHING about 12'2'' panels Smile !! Yes, now that you've modified your statement, it makes better sense.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2021 at 5:08pm
Clap   Clap   Hug
but MOST IMPORTANT.... Did I get all the WORDS spelled right ?
Edited by steve(ill) - 21 Feb 2021 at 5:08pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2021 at 6:19pm
In my workshop I bought steel panels and used a modified drywall jack to bring up to the trusses.  Had to order Ceiling rated truss to do this as the truss company stated if used in a Barn configuration are not designed for Weight carry underneath.  These Were NOT Barn truss in my Shop, had same load rating as House free span ceiling carry truss.
