Shipping Small Heavy Items ???
Macon Rounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Topic: Shipping Small Heavy Items ???
    Posted: 17 Nov 2016 at 5:45pm
Hey Fellas !!!
What is the most economical way to ship 20 to 30 pounds items that a person sells for say $50 to $100.
I have been using Fastenal for shipping PALLETED large heavy items . Their 3PL "Third Party Logistics" are fantastic and easy to use.
However small $100 items don't justify the cost of shipping on a pallet.
USPS flat rate boxes are often to small for my items.
looking at 12x12   and    18x18   box sizes.
All suggestion welcome.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2016 at 11:25pm
bump
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2016 at 11:54pm
try' speedy bee. they do me right' would haft to look you up a number if needed.
ac160 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac160 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2016 at 5:40am
UPS is not overly bad sometimes.  I just shipping a 43lb item w/insurance for $35.  It went across a couple of state.
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2016 at 5:59am
Never heard of Speedy Bee, but...I have heard of Spee-Dee Delivery, but they're only in 7 states and a small portion of MO., which their last stop is me! Half or less than UPS on anything! That won't do you any good though, Ben, so back to square one. One thing about UPS though, is that your package includes the first 100.00 insurance automatically. Anything to do with USPS you have to pay for yourself. Something to take into consideration.   Rick
DanC911 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanC911 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2016 at 4:11pm
I use FedEx Ground for a lot of my shipments.  They are routinely less expensive than UPS.  But I suggest that you ship to a business address if you can because if you ship to a residential address it will go via FedEx Home which is more expensive that UPS.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2016 at 4:46pm
Spee Dee Delivery only services you mid west fellas as Rick had indicated.
Will check into shipping FedEx to a business, and the others too.
Thanks for the suggestions.
sparky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2016 at 9:20pm
Check and see what the cost would be in your own box through USPS. Worth a try. I also have had good luck shipping larger items with Fastenal.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2016 at 8:48am
The "choose your own box" through the usps is a good dela if there's no weight whatsoever. Anything too big and heavy for a flat rate box is very expensive through usps. I use Spee-dee a lot, but yes, they are only here in the midwest, IL,IA,NE,WI,MN,SD, limited ND & St Louis MO area. I end up using ups on other things, but am following this for other options.
