Shims under main cap and Rod caps ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2016 at 5:20pm
Originally posted by Whtbuch Whtbuch wrote:
If I'm not mistaken how I understand the paperwork the main would be 2.250 in . With a .002 oil Clarence. But that is how I understand it I could be wrong? But I did not see A Rod bore diameter.
That is the JOURNAL diameter. You have to add clearance and twice the thickness of the shell bearing to get close to the actual bore size.
 If you could mic across the shell insert, the bore should be about .002 smaller than the OD of the bearing.
Edited by CTuckerNWIL - 14 Dec 2016 at 5:23pm
