Shimming a D17 power director |
Post Reply |
CrestonM
Orange Level Joined: 08 Sep 2014 Location: Oklahoma Points: 8361 |
Posted: 27 Sep 2016 at 10:48am |
Posting for a friend of mine who has a D17.
It's a 1958 D17, and the PD doesn't snap into each range. Just kinda slides in. He's thinking it may slip when it gets a big load on it. Apparently there is a way to shim it up to make it snappy. Could someone explain the process? He's read the book, but it's still over our heads. Thanks
Dans 7080
Orange Level Joined: 05 Feb 2010 Points: 1146 |
Look in the knowledge based section. There is a video of it.
When someone tells you Nothings Impossible, Tell them to slam a revolving door
CrestonM
Thanks! I found it. That will surely be a great help.
Skyhighballoon(MO)
Orange Level Joined: 11 Sep 2009 Location: Pilot Grove, MO Points: 3115 |
Creston - what is not explained in that video is if the PD has worn out rollers and pre-load plate ramps, shimming it back up to spec might not be enough and could make it worse if it pops out of range. If the PD pop out of range, esp. the high range, but won't slip if you hold it in, then likely new rollers and a preload plate is going to be needed in the PD to make it right. Mike
1968 Gleaner EIII w 10' & 330 1969 180 gas 1965 D17 S-IV gas 1963 D17 S-III gas 1956 WD45 gas NF PS 1956 All-Crop 66 Big Bin 303 wire baler, 716H, 712H mowers |
Jack(Ky)
Orange Level Joined: 12 Sep 2009 Location: Ky Points: 1151 |
I would bet money it is just the rollers and the plate worn. My D14 wouldn't even stay in on the low side. I built up the worn plate and put in new rollers. It takes a little tinkerin' to get it to snap in just right but it can be done. You may be better off to buy a new plate or a good used one. JP
'59 D14 '68 170 Diesel '81 7020 40 All Crop
Post Reply | |
