Shifter boot for a WF / WC
 Rating: Topic Rating: 1 Votes, Average 1.00  Topic Search Topic Search  Topic Options Topic Options
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Topic: Shifter boot for a WF / WC
    Posted: 17 Jan 2021 at 7:08am
I am working on one of my WF's which needs a shifter boot. How do you get a new shifter boot over the reverse lock out mechanism ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2021 at 7:16am
I removed those things from the lever when I put a new boot on my RC. then put everything back together after the boot was in place.
ac hunter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac hunter Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2021 at 8:07am
This may not sound very professional but for my '36 WC I cut mine then glued it back together. Used Loctite super glue for the adhesive; it dries very quickly and is strong. Make a clean  cut with a very sharp knife and glue a little at a time being very careful to get the two sides aligned. You will have to hold it  in place for 30-45 seconds. Take your time and I  don't  think anyone would notice what you did. I would have ruined the original shifter knob  getting it off and probably other damage  getting the linkage removed. Good luck.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2021 at 10:09am
Paul, I tried getting the pin out of the "swivel" on the bottom of the reverse lock out. Is it a rivet ? I heated it all I dared, but couldn't get it to budge. I was afraid to screw everything up, so I decided to ask what other people were doing.
If this pandemic ever gets under control, I still plan on stopping in to see you !
ac hunter, I was thinking about doing exactly what you are talking about. I was hoping someone would say they had tried it.
I did get the knob off. It was in pretty rough shape, so I wasn't too concerned about damaging it, but it came off in pretty good shape.
Thanks for the replies, guys !
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2021 at 11:36am
If I remember right (that was about 30 years ago) That pivot plate is just on with a rivet. Mine was somewhat loose and needed a new rivet anyway.
  Hopefully now that there is a vaccine that is getting out to people, y'all will be able to have your show in June. As for me I'm only writing my plans in pencil for now. I'd like to be able to bring a trailerload of NOS parts to the swap meet there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2021 at 10:12pm
Well if they don't do it there Paul, you're more than welcome to bring it to Hutch for the Gathering of the Orange....Wink Wink Wink hint, hint LOL
fleeter allis fan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fleeter allis fan Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2021 at 8:36pm
I replaced the boot on my WF a while ago. I was able to remove the knob and by squeezing the reverse interlock tight to the shaft, managed to stretch the boot enough to get it over and work it down until it was in place. Had to stretch it quite a bit, but I got it into place without taking anything apart or without damaging the boot. A little bit of liquid dish soap might help if necessary.
I'm a man...and I can change...if I have to... I guess.
'44 B, '46 WF, '49 G, 810GT, 916H, 620
JW in MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2021 at 8:56pm
I did the same thing on my WC, time, patience and perseverance.  Boot fits tight now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2021 at 6:08am
Thanks for the responses guys ! I really appreciate all the ideas !!!
This page was generated in 0.101 seconds.
