Shift boot change for WC/WF
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Topic: Shift boot change for WC/WF
    Posted: 24 Mar 2025 at 5:31pm
I am trying to put a new shift boot on one of my WF's. How do you get it over the reverse lockout mechanism at the bottom of the shift lever?
Does anyone know if the rocker for the lockout mechanism has a small bolt threaded into the shift lever or is it just a rivet?
Any tips on how to install a new boot?
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2025 at 9:33pm
i took all of mine apart on my wc it all needed worked over any way.   but put a big tapered punch in the boot and run it under hot water ,  push punch in farther and then have every thing greased and ready to go when you remove the punch before the hole gets small again
This page was generated in 0.045 seconds.
