setting up a plow |
Rfdeere
Joined: 11 Sep 2009 Location: Idaville, IN Points: 3283 |
Topic: setting up a plowPosted: 02 Feb 2011 at 7:23pm |
To add to gold642's comment, the front wheels need to be blocked up to, if it is a narrow front. Wide front just block the left front.
http://www.rumelyallis.com |
gold642
Posted: 02 Feb 2011 at 5:58pm |
Are you using 12 inch, 14inch or 16 inch plows? Inside right rear tire to first point should be the same distance as the plow width i.e. 12 inches for a 12 inch bottom. Remember you want your right tire at plow depth and your left tire is at top of dirt. To achieve this, First place the tractor and mounted plow on a flat concrete floor or driveway. To set your plow, if you want to plow 6 inches deep,place a 6 inch block under your left rear tire. Use a 5 inch block to set 5 inches deep. With the lift handle down .Adjust your plow so both bottoms are sitting flat on the floor both directions. This should get you every close to being adjusted. After you shine the bottoms up . you might want to make fine adjustments in the field.
Brian Jasper co. Ia
Posted: 02 Feb 2011 at 5:39pm |
I noticed that there is going to be a "seminar" at the Hutchinson show this year on setting up a plow. Isn't it also a GOTO this year? Sounds like this would be a show not to miss...
allis restorer
Joined: 05 Dec 2010 Location: Rib Lake, WI Points: 184 |
Posted: 02 Feb 2011 at 3:34pm |
thanks for your help
ALinIL
Joined: 20 Sep 2009 Location: Frankfort, IL Points: 316 |
Posted: 02 Feb 2011 at 9:35am |
Allis Res - Here is a picture that may help you with adjustments |
Robert Mull Georgia
Joined: 14 Sep 2009 Location: Woodstock, Ga. Points: 211 |
Posted: 02 Feb 2011 at 6:47am |
Usually on tractors like the CA, B, C using a two bottom plow the wheels are closed in all the way.
allis restorer
Posted: 01 Feb 2011 at 2:58pm |
ok thanks, i know its a little early to start thinking about plowing but i was just thinking about it, so i can be ready when the time comes
Denis in MI
Joined: 15 Sep 2009 Location: Norvell, MI Points: 832 |
Posted: 01 Feb 2011 at 2:54pm |
The distance from the inside of the tire to the first plow bottom should be the same as the distance between the two bottoms
1938 B, 1945 B, 1941 IB, 1949 C, 2 1938 WCs, 3 1950 WDs, 1951 WD, 2 1955 WD45, 1957 D-14
allis restorer
Posted: 01 Feb 2011 at 2:51pm |
i have a 2 bottom plow for a Allis CA, and we converted it to a 3 point, what should the distance be from the inside of the rear tire to the point of the first plow point? any help would be appreciated, thanks
