setting timing on a 1952wd
dudley wallace View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dudley wallace Quote  Post ReplyReply Direct Link To This Post Topic: setting timing on a 1952wd
    Posted: 08 Jan 2018 at 3:01pm
how do you set the timing on a 1952 Allischalmers model  WD using a timing light where are the timing marks at just want the timing just right it could be out a little I just want it to be as strong as it can be thanks for your help never did this before on a tractor a lot of cars and trucks
a member of hendricks county antique tractor and machinery association club.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2018 at 3:20pm
It's pretty much the same concept as a car or truck. Connect your light to the front plug wire and there is a hole in line with the rim of the flywheel to view the marks. There will be a TDC line and a FIRE line. Run the engine at full throttle and center the FIRE line in the hole by turning the distributor or magneto as needed.
This page was generated in 0.197 seconds.
