d15 series ii three point on series i d17 |
HudCo ![]() Orange Level ![]() ![]() Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3926 |
![]() ![]() ![]() ![]() ![]() Posted: 12 hours 58 minutes ago at 1:24pm |
i have a d15 17278 sn at the shop to re pack some loader cylinders and was looking at the factory three point hitch has any one tryed putting that setup on the d17
Edited by HudCo - 12 hours 48 minutes ago at 1:34pm |
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 22001 |
Some things to consider: #1. A 4500 lb D-15 series 2 can destroy one of those category 1 hitches if used heavily. How long would it last on a 5500 lb D-17 ?? #2. I think the torsion bar and draft arms would bolt right on, but how do you intend to get the splined lift arms off the splined shaft?? You could remove the lift arm housing and remove both shafts with the lift arm still attached, I guess. It would mean removing the lift arm housing on both tractors to get it done.
Tracy Martin TN ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10821 |
The D10,D12 and D15 3 point hitches were too light!The mounting bolts were placed incorrectly. JMHO, Tracy
