Series 610 all terrain forklift
edognight View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote edognight Quote  Post ReplyReply Direct Link To This Post Topic: Series 610 all terrain forklift
    Posted: 05 May 2025 at 7:05am
I have my forklift up and running with the hydraulics working! Thanks to the help on this forum. I had asked a couple questions previously and got some good direction thanks to the folks here.
Looks like one last problem. The reverse seems to work with the shuttle clutch, in all the gears. the tractor moves with letting the clutch out, and pulling the hand lever back. There does not seem to be a neutral with the hand lever, like the machine is stuck in reverse.
If I push the lever forward, and let the clutch out, the tractor seems to sense severe resistance, like you are pushing against a wall, and it dies from the resistance to moving forward. Something is wrong with the shuttle clutch, I think. It sat for a long time with the inspection cover open...
I am not sure how to explain it any better.
Post Options Post Options   Thanks (0) Thanks(0)   Quote edognight Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2025 at 8:40am
I forgot to mention the forklift is based on a d15 tractor and the forward and reverse are opposite on this model because the seat is backwards to face the big wheels and forks. I understand some tractors came with the shuttle clutch. In tractor terms, it is stuck in drive and won't reverse.
RedHeeler79 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RedHeeler79 Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2025 at 9:06pm
As I understand it, the clutch itself is no different than a standard power director in a D15. The shuttle (forward-reverse) function is achieved by additional idler gear in the torque tube ahead of the clutch compartment, which makes the shaft turn in reverse rotation when it’s in the respective position. It sounds like one side of the hand clutch is stuck. That would make it try to drive in both directions when in forward position, killing the engine. Also likely explains the “no neutral” condition. The clutch was probably engaged in the reverse position while it sat for a long time with the clutch inspection cover removed, causing the plates to stick (seems plausible if the oil was drained and the cavity exposed to the elements for an extended amount of time). I would remove the cover and see if you can gently unstick the plates with a pocket screwdriver or similar tool with the lever in neutral, or opposite of the “stuck” position. Should be pretty obvious once you take a close look at the clutch. Hopefully it won’t require a teardown and replacement of the clutch plates. I have an I-600 forklift that needs the shuttle clutch plates replaced. Looks like an extra fun job due to the full length outer frame of forklift. Keep us posted on your findings.
Post Options Post Options   Thanks (0) Thanks(0)   Quote edognight Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2025 at 6:33am
That is a very good answer!
I was thinking similar things, but I am way less knowledgeable. It did sit for years with the cover open. there were lots of leaves and trash in the bottom of the torque tube. I am going to let it run and play with it a little, I just got that chamber filled with fluid, ill put a filter on the oil lines and see. I can hear the clutch plates turning in the oil. and I hope I can get it unstuck. then I'll check on the clutch plates thru the cover. Thank you soooo much, I think you are dead on...
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2025 at 9:58am
I can't imagine bearings not being rust balls in that compartment. Good luck!
Post Options Post Options   Thanks (0) Thanks(0)   Quote RedHeeler79 Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2025 at 12:08pm
I would fear that too, Steve. May require a split to get all the issues resolved. Someone messed up pretty bad by leaving that clutch compartment open to the elements….
Post Options Post Options   Thanks (0) Thanks(0)   Quote edognight Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2025 at 5:54pm
I got that junk moving!
I think you guys were exactly right. I got it running and did a bunch of reverse easing in and out, then switching forward till it almost died and then back and neutral and easing it forward, and it finally let go, it went forward a little, then I just kept working it. It got better and better. I might be out of the woods.
I was going to put a filter on the hose running to the transmission oil cooler, and just keep trying it. hopefully it will be ok.
thanks for all the help, you guys really nailed it on that one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote RedHeeler79 Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2025 at 6:53pm
Hopefully it all holds together for you. Report back with your results after a while. I’d be interested to see how it turns out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2025 at 8:40am
It may well function but I doubt it will "be okay".
