Series 3 flexhead on K2
67-d10 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 67-d10 Quote  Post ReplyReply Direct Link To This Post Topic: Series 3 flexhead on K2
    Posted: 4 hours 38 minutes ago at 3:05pm
Wondering if anyone has put a series 3 flexhead (313) from a F2/3 onto a K2?
My concern isn’t about the hydraulic or electronic side of things. That’s secondary, my question is actually fitting it onto the combine.
Were they built like earlier models to move the hooks in? Drive shafting is also a concern.
We are pretty darn handy with the welder and torch, so that can make just about anything possible, but just wondering if anyone has been through the process.
If I can get it locked onto the combine, and power through the shaft, the rest is down hill.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 29 minutes ago at 5:14pm
Centered version
1st. Relocate both of 313’s top pipe hooks & lower wedge hooks inward to align to K/K2 feeder housing. After that’s accomplished, then bolt in 2 custom made side filler sheets (5”?) to each side to enclose F/F2-3 gaps. Header feeder opening should measure same height for both K & F….? F is 10” wider (1 straw walker) than K.
2nd. Lengthen 313’s left side drive shaft. Think that shaft’s outer drive sprocket is probably keyed?
Try to Fab-install a short(5-6”?)shaft adapter that may slide over original keyed end (ie original drive sprocket that fits keyed end with a welded black pipe extension to it & then another drive sprocket welded to it other end where it accept K2’s drive chain). This option along with 1st step above renders 313 adaptable/readily swappable between F & K.
If extending shaft with more shaft, locate a good non-bearing area before drive sprocket end to cut & lengthen it. Now it’s set for K only though….
Whichever, the drive shaft is not a high rpm shaft so good/decent alignment should suffice?
3rd. Your local combine salvage yard may have the required hydraulic/electrical components from parts combine.(f3/M3/L3?) that could be swapped into K2.
OR…….
Left-of-center version
1st. Align K’s left side of its feeder housing direct to 313’s top pipe hook & lower wedge hook. Then relocate both of 313’s right hooks (top pipe/lower wedge) to K’s feeder housing’s right side. And then fab/bolt in 10” filler panel to cover F’s gap. Header drive sprocket is ready to chain as is. Done…!
Most of header’s weight is on left drive side, so K’s header lift cylinders will probably appreciate being 10” closer to left side? And K’s cab ladder, left wheels, etc should clear cut crop just fine. Only issue(s) would be tire tracking per stalk damage if cut stalks line up with tires(sorghum?)?? Header is 10” offset to right, if that matters? Crop feeding into feeder beater housing should be ok? Just have to try & see. Worst is 1-2 of cross auger’s right side center feed fingers might need to be removed??
Edited by AC7060IL - 1 hour 28 minutes ago at 6:15pm
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 29 minutes ago at 7:14pm
You may have to extend the end of your auger flighting in the middle. If feeding in is a problem
