seperate torque tube from transmission WC
Redwood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Redwood Quote  Post ReplyReply Direct Link To This Post Topic: seperate torque tube from transmission WC
    Posted: 25 Feb 2012 at 6:35pm
Tear down is coming along good
I need to remove the bell housing and the transmission from the torque tube.  I loosened the seal cover.
Does anyone have a trick to seperating these parts?  As far as I can see from the tractor and the exploded view there is no pin or coller holding the two together.
The shape of the back of the torque tube doesn't have much to pry on or jack.
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2012 at 6:51pm
Scott, how are you going at it? Is the motor out? All the bolts out of the tranny? Frame rails loose.
Are you planning to come out as a unit like this?
they just mesh splines and slide together and apart
look through these, it may answer more of your questions -
http://s33.photobucket.com/albums/d84/Joecdeere/1941%20WC/?albumview=slideshow
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2012 at 7:13pm
Redwood...I take it that you're talking about taking the transmission itself loose from the bell housing...right? If so,there's another bolt on the bottom on the inside of the bell housing that needs to be removed first. then it will come apart. Hopes this helps.  Rick
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2012 at 7:15pm
Redwood...I'm sorry,but I misunderstood your question,I guess. I believe that Joe has answered that though.  Rick
Post Options Post Options   Thanks (0) Thanks(0)   Quote Redwood Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2012 at 8:42pm
Thanks for the pictures that helps clear it up for me.  I think if I put a chain tightener on the front I can ease the spline off.  I didn't want to stress it, in case I was missing something.
I'm leaving the bell housing attached until I get it out.
In the end all of it is coming apart, Just trying to get down to the differential and final drives.  That where I'll start the rebuild and fix the rest as I add it back on.
Looks like that restoration was pretty extensive.  Is it finished? I didn't see a completed photo.  Looking good from what I did see.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2012 at 8:59pm
Scott, It was my wifes great-grandfathers, so I thought it deserved doing it right.
It's all done, awaiting time and money to paint it
Ford 345C TLB
Post Options Post Options   Thanks (0) Thanks(0)   Quote Redwood Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2012 at 11:35pm
It will be nice to see with the paint.
I bet it means a lot to your wife and her family
