sediment bulb
Steve R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve R Quote  Post ReplyReply Direct Link To This Post Topic: sediment bulb
    Posted: 29 Nov 2010 at 2:19pm
Any suggestions on how to get a very stuck sediment bulb off without breaking it? The guy I'm working for just got a JD A (I Know)  and we have tried to get it off but it is really stuck.
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2010 at 2:29pm
They are made of pretty thick glass and don't break that easy.
I know, I dropped them on a concrete floor and they bounce. LOL
Wrap a dish towel around it and tap it with something like a rubber hammer or a large screw driver handle while you pull down on it.
RyanTN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RyanTN Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2010 at 3:29pm
Have you tried spraying it down (around the seal) with carb & choke cleaner?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2010 at 5:50pm
Jeff you had much better luck than me! After I cleaned the one from my D-14, it slowly rolled off the bench and smashed into a zillon pieces! Said 'oh well', I'll just grab the one off the other D-14.OOPS, already been there,done that. 2 hour trip to the 'local TSC' and I bought TWO complete bowl assemblies.Nope, 2nd ones not on the second D-14...I've already misplaced it !!!!
tomdavison View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomdavison Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2010 at 5:59pm
I would heat it slightly with a hair dryer and then use the above suggestions.
Rick of HopeIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2010 at 6:53pm
Usually I can't get them to stop leaking.  I can't imagine one being stuck solid.
JohnCinMd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCinMd Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2010 at 7:08pm
I soaked the whole assembly in a can of gas for a few days, then tapped it till it separated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2010 at 8:12pm
jbmiller, Tractor Supply has plenty more.
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2010 at 8:26pm
I think they are called sediment  "bowls"......bulbs make me think of tulips....and spring....can't wait LOL!
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisChalmers37 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2010 at 9:00pm
PB Blaster. It unlocked the wheel bolts on my WC that had never been took off.
This page was generated in 0.178 seconds.
