seat cushion info. needed 190,200,210 etc.
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Topic: seat cushion info. needed 190,200,210 etc.
    Posted: 15 Nov 2024 at 9:02pm
I need some opinions from some folks who have bought replacement aftermarket seat cushions. I need the white, 3-piece set that would fit the 190-220 etc. ( I believe they are for the super deluxe seat frames)
They offer some with wooden backing or steel backing, I'm also seeing some that are Embossed.
Wondering what you bought?
How it fit?
Where did you buy it from?
Thank You for your help.
Dan
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2024 at 10:01pm
Look online for K & M Mfg. Co. Then Go to their dealer locator page, find the nearest dealer.
 They sell a nice set for the Deluxe seat, have metal bases / vinyl covers and offer in white or black & white. Listed as "AC 180" in the catalog. Not cheap but fit correct and mine seem to be good quality. You'll be looking at around $500 for the 3 pieces.
 They also have "AC 7001" comfort, it fits my late AC200, show 2 seats (7001 fabric or vinyl & 201 vinyl) both w/ adjustable arm rests and a cushion set AC210 to fit 100 , 200, 7000 series tractors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2024 at 12:38pm
I would like the deluxe seat complete for my 220. Have no seat frame to attach cushions to. Have a torched off bottom pan with a boat seat screwed to it. I don't think you can buy what I want.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2024 at 6:31pm
Steve, DJS sells a frame for the deluxe seat, if you can weld/fab a little it could be added to the suspension. DJS also sell the pins & bushings, arm for shock, shock, the things needed to recon seat suspension.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2024 at 1:21pm
thanks Chris. I need to look into that.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2024 at 2:06pm
ACdiesel, I’ve purchased replacement seat bottoms & backs or “entire seat” w frames from K&M, Salvage yards, & our local custom upholstery shop.
K&M is ok/good value, some times I luck out at salvage yards & locate good OEM seats, but have always received best value from our local upholstery shop. A good upholster person can offer a variety of options based off either OEM or custom applications. Cab vs no cab? Outdoor conditions? Most times shop will refurbish OEM seat/frame at reasonable cost, give solid advise about most durable coverings, foam cushions, colors, etc,, at most economical values.
Edited by AC7060IL - 17 Nov 2024 at 2:10pm
jvin248 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jvin248 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2024 at 8:36pm
Seems like you have a rough starting point with half a frame.
But I've had good luck with buying vinyl at Hobby Lobby
/Etc. Contact cement to stick it down over original or sewing to a removed cover as a pattern.
I do refurbishing for functional use not trying to get back to recreating factory exact restoration that you may be chasing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2024 at 10:07pm
I would send you to Rick, I got all 3 pieces from him for my190 XT a few years back. Metal backing and they are still in great shape. He sold good quality parts. I appreciate all he did for me.
This page was generated in 0.099 seconds.
