Seasonal disconnect? |
whatscooking
Topic: Seasonal disconnect?Posted: Yesterday at 5:51pm |
What does it take to seal that shaft where it goes into the side of the tractor?
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8987 |
Posted: Yesterday at 6:09pm |
what tractor?
AC720Man
Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5477 |
Posted: Yesterday at 6:18pm |
I’m guessing 6060,6070,6080?
Posted: Yesterday at 6:45pm |
The D-21 PTO seasonal disconnect shaft oil seal is an O-ring (certain size and hardness) that fits in a groove on the levers shaft. To remove the shaft, one must remove a roll pin (or maybe a solid groove pin) from the inside of the four-speed transmission. It's normally a hammer and punch kind of removal. I've never done one in chassis before and don't know how much room there is to work in that area after removing the platform and shift cover from the top of the transmission. I'm pretty sure if the four-speed was split from the rear end and rolled ahead 3 or 4 feet, there would be a way to drive out that pin from the rear. If there's enough room from above, I'm sure I could figure out a way to remove the pin from the top, instead of a split. Anyway one goes about it, easy it will not be.
Edited by DrAllis - Yesterday at 6:46pm |
whatscooking
Posted: Yesterday at 6:51pm |
If it's split for a clutch does that help? |
Posted: Yesterday at 6:56pm |
That would require lifting the complete control module off the top of the bell housing and splitting it from the front of the four-speed transmission. Probably could be done that way but a lot of work. A rear split is easier. Is there a clutch problem too ??
whatscooking
Posted: Yesterday at 6:59pm |
Transmission fluid out the hole.
