Seasonal disconnect?
whatscooking View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Topic: Seasonal disconnect?
    Posted: 11 hours 50 minutes ago at 5:51pm
What does it take to seal that shaft where it goes into the side of the tractor?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 11 hours 32 minutes ago at 6:09pm
what tractor?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 11 hours 23 minutes ago at 6:18pm
I’m guessing 6060,6070,6080?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 hours 56 minutes ago at 6:45pm
The D-21 PTO seasonal disconnect shaft oil seal is an O-ring (certain size and hardness) that fits in a groove on the levers shaft. To remove the shaft, one must remove a roll pin (or maybe a solid groove pin) from the inside of the four-speed transmission. It's normally a hammer and punch kind of removal. I've never done one in chassis before and don't know how much room there is to work in that area after removing the platform and shift cover from the top of the transmission. I'm pretty sure if the four-speed was split from the rear end and rolled ahead 3 or 4 feet, there would be a way to drive out that pin from the rear. If there's enough room from above, I'm sure I could figure out a way to remove the pin from the top, instead of a split.  Anyway one goes about it, easy it will not be.
Edited by DrAllis - 10 hours 55 minutes ago at 6:46pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Posted: 10 hours 50 minutes ago at 6:51pm
If it's split for a clutch does that help?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 hours 45 minutes ago at 6:56pm
That would require lifting the complete control module off the top of the bell housing and splitting it from the front of the four-speed transmission. Probably could be done that way but a lot of work. A rear split is easier. Is there a clutch problem too ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Posted: 10 hours 42 minutes ago at 6:59pm
Transmission fluid out the hole.
