Search for HD4 Serial numbers
stileseverett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stileseverett Quote  Post ReplyReply Direct Link To This Post Topic: Search for HD4 Serial numbers
    Posted: 30 Oct 2019 at 5:14am
The old AC HD4 appears to be a model from somewhere in the 70's.  One source indicated the numbers would be on the lower frame on the front of the dozer, but were not.   Have been unable to find a placard or numbers anywhere else.  Would numbers from the  engine give a clue as to the date of manufacture?
Everett Stiles
Macon County
North Carolina
Randaleky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randaleky Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2019 at 7:48am
Check the front of the torque tube just behind the engine oil filter . mine is on the end where the engine block and tube connect. should say HD4  _____
Most are just in front of the front grill on flat frame in the middle of it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote stileseverett Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2019 at 2:43pm
Thanks very much.  I'll go look!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randaleky Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2019 at 6:37pm
ok. you are welcome.  also welcome to the forum.  There are a lot of knowledgeable people on here.  can you send some pics of your HD4 ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2019 at 7:30pm
Randal, sent you a pm. Tracy
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2019 at 4:41pm
My HD4 has the number on the front flat part of frame ahead of the grill piece - right side when facing fromt of machine - they were partially covered by the metal grill guard or metal plate bolted into front of machine
Post Options Post Options   Thanks (0) Thanks(0)   Quote stileseverett Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2019 at 8:29pm
Randeleky:  Just as you say:  On the top of the front frame under the grill.  Prithee, where do I look for the year of manufacture.  Thanks a lot!
pinball View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pinball Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2019 at 10:22pm
just go on the net . and type in allis chalmers h4 for a search. you will find out all the specks and serial numbers.
This page was generated in 0.234 seconds.
