Seal part # crossreferance |
Post Reply |
DSMhoneyyard&farm
Bronze Level Joined: 04 Mar 2024 Location: Michigan Points: 11 |
Posted: 18 Mar 2024 at 10:10pm |
I'm going to need to get some new seals for my model B. Does anyone know where to find a cross reference for seals from old part #'s to currently available seals? The seal part #'s I have are as follows;
Mikez
Orange Level Access Joined: 16 Jan 2013 Location: Usa Points: 8379 |
The bottom two numbers are still good numbers. We could help you if you don’t have a dealer you’re using near you.
I’ll look into first number more tomorrow
AaronSEIA
Orange Level Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2551 |
First add a 70 to the front to get the modern AC number. Then a simple Google search should find them. OK Tractor or DJS may have them in stock. Aaronseia
Mikez
We can help you get those parts
DanielW
Bronze Level Joined: 19 Sep 2022 Location: Ontario Points: 165 |
If you don't have luck at an AGCO dealer, I always use the SKF seal cross reference website. Scroll over to the 'Search by Dimension' tab, make sure you select 'Dimensions in Inches' (not millimeters) and make your input ranges a little wide (i.e. if you measured the seal at 5/16" wide, put the range at 0.1875 to 0.5 (3/16" to 1/2", but you have to use decimals on that site). Once you have the SKF equivalent #, any NAPA/auto parts store/industrial supply can order them for you. In my experience the SKF and Timken seals are often better quality (and much cheaper) than the ones you'll get at the dealer.
Edited by DanielW - 21 Mar 2024 at 7:03am |
Post Reply | |
