Seal for hydro on a 912 |
Lon(MN)
Joined: 11 Sep 2009 Location: Merrill Wi Points: 2048 |
Topic: Seal for hydro on a 912Posted: 29 Mar 2017 at 5:12pm |
The seal next to the pump is leaking. The number is CR528992. Went to my bearing house and they could not find a listing.
Any suggestions on finding a new seal?
ACmowerguy
Joined: 20 Apr 2010 Location: Winfield, MO Points: 1210 |
Posted: 29 Mar 2017 at 9:10pm |
Its probably available through Simplicity under their number. When you say next to the pump, do you mean its on the axle case or is it on the Sunstrand hydro pump. At the rear when looking at the tractor or on the pump input shaft on the right side?
Edited by ACmowerguy - 29 Mar 2017 at 9:11pm |
Lon(MN)
Posted: 29 Mar 2017 at 10:07pm |
Looking at the tractor from the rear, on the left side is a shaft that runs horizontal. Two bolts hold a cast piece that is part of the pump. Just to the left of the disconnect valve. Not sure why the shaft comes out there anyway, nothing for it to run. The shaft diameter is 5/8, but the seal OD is 1.128.
Thanks for your help
Mikez
Posted: 29 Mar 2017 at 11:25pm |
Above the filter. Is it just coming out where the shaft comes out, there's a ball bearing and a needle bearing in the little cast piece bolted on there with a oring where it's bolted to housing. If its what I think your talking about. Like ACmowerguy said you can get it from simplicity
